Firebox controller for ableton
jamie3
Did you modify it for the correct number of AINs?
AUAIMBCTG?
well i grounded everything yes.
i also tried without using any AIN modules (just directly hooking up the pot to the Core and the pin value still changes when the pot is moved.
here is a dump of the output when moving the pot in UNMUXED mode
00000000685040 ms | [b0 28 4A] Channel 1: CC LSB 8 (Balance) value: 74
00000000685052 ms | [b0 18 4A] Channel 1: CC Undefined value: 74
00000000685189 ms | [b0 38 4A] Channel 1: CC LSB 24 (Undefined) value: 74
00000000748217 ms | [b0 20 49] Channel 1: CC LSB 0 (Bank Select) value: 73
id like the midi output to be as follows:
B0 28 4A
B0 28 4B
B0 28 4C
so here is the initial layout of the front panel. still needs some work and more exact measurements
I am building a midi controller for ableton. mainly for Djing.
It will contain the following
6 channels
  - volume
  - 3 eqs + kill
  - 3 assignable effects + on/off
  - channel select
Master
  - volume
  - 3 eqs + kill
  - 2 assignable effects + on/off
  - master select
Tempo control
Mackie Navigation
  - up, down, left, right
  - play clip/scene
40x2 character LCD (red)
Built in sound card (likely Motu traveller)
  • 4 months later...
hey guys,
havent been here in a long time. been busy rennovating my house.
anyways im back to work on my controller. i've decided to keep things simple, and the reason being is because a friend of my gf owns about 40K in machine shop equipment so i am able to finally experiment with my front panel. i decided i am going to make things simple, use the mixer briefly for a few gigs, and see what is missing before i add more buttons, lights, etc.
here is the panel cut. this weekend i wll be cutting the holes for the knobs.
hi res image here
http://3.bp.blogspot.com/_ZdR1AjzO6Bk/STxXSUm32-I/AAAAAAAAADE/uaSGgbghcsE/s1600/DSC02803.JPG
if u cant see the image visit my blog www.jamiea.ca
FYI, the front panel is made from aluminum. I picked up a piece of aluminum maybe 60" x 25" at a local metal shop for about $20 CDN. So essentiall i can build two front panels from the piece of aluminum i purchased! yippee!
