jamie3 Posted July 30, 2008 Posted July 30, 2008 not sure if this is the correct place to post this.I have my front panel designed in .fpd format. I need to convert it to .dxffront panel express offers a plugin to do the conversion however i am cheap. would anyone here who has the filter be able to do the conversion for me?cheers,jamie
nILS Posted July 30, 2008 Posted July 30, 2008 There are people on this forum that offered doing this - just search around a bit.You could setup a file printer (any printer, check "print to file" option) and convert the .ps to .dxf using ps2dxf.exe that is available on the net somewhere.
jamie3 Posted July 30, 2008 Author Posted July 30, 2008 There are people on this forum that offered doing this - just search around a bit.You could setup a file printer (any printer, check "print to file" option) and convert the .ps to .dxf using ps2dxf.exe that is available on the net somewhere.yeah i seen the fpd -> pdf -> dxf, but i was worried that it would not retain the depth/thickness information.
jamie3 Posted July 30, 2008 Author Posted July 30, 2008 S_LID_ED_E_2D_FREE has built-in DXF export :P :Pi googled this an no results
nILS Posted July 30, 2008 Posted July 30, 2008 I'd like to solve: "Solid Edge 2D Free"http://www.midibox.org/forum/index.php/topic,11892.msg96614.html#msg96614
stryd_one Posted July 31, 2008 Posted July 31, 2008 Gee that musta been hard. dstamand do you work for those guys or something?Does it open FPD files too?
dstamand Posted July 31, 2008 Posted July 31, 2008 Gee that musta been hard. dstamand do you work for those guys or something?Does it open FPD files too?No, you guys are looking for free software and this is a damn good one!No, FPD is proprietary file format.
