I managed to get my own C program running on MIOS, based on the sdcc_skeleton files. Now I want to integrate TKs random function into my program:
;;  This function generates a new random number
;;  OUT: new random number in SEQ_RANDOM_SEED_[LH]
SEQ_CORE_GenRandomNumber
  SET_BSR  SEQ_BASE
  movf  SEQ_RANDOM_SEED_L, W, BANKED
  mulwf  SEQ_RANDOM_SEED_H, BANKED
  movf  TMR0L, W
  addwf  PRODL, W
  movwf  SEQ_RANDOM_SEED_L, BANKED
  movlw  0x69
  addwfc  PRODH, W
  movwf  SEQ_RANDOM_SEED_H, BANKED
  return
How do I define this as an assembler function that I can reference in C? I could not find a mixed C/Assembler example project.
Many thanks, ALEXander.
Hi Alexander,
did you really search for examples?
Here you will find a lot of examples for accessing assembler code from C with a wrapper:
http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fmodules%2F
This example is a bit more simple, only one file which references (and contains) the assembly code:
http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fexamples%2Fsm_c_example1%2F
The mclock.c file of this application demonstrates, how to use inline assembly code:
http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fclockbox%2Fenhanced%2F
OK, I got it working. I generated a simple application sceleton which uses a c and an asm part, and links them both together. so far, only one byte is supported for parameters or return values. anybody care? I will extend it soon.
Best, ALEXander.
BTW: is SET_BSR "Set the Bank Select Register"? Took me a while to figure that one out. But now it works.
Would be cool if you could show the various ways of doing it... Functions, variables, inline, included, via modules, etc
