wackazong Posted August 25, 2008 Report Posted August 25, 2008 Hi,I managed to get my own C program running on MIOS, based on the sdcc_skeleton files. Now I want to integrate TKs random function into my program:;; --------------------------------------------------------------------------;; This function generates a new random number;; OUT: new random number in SEQ_RANDOM_SEED_[LH];; --------------------------------------------------------------------------SEQ_CORE_GenRandomNumber SET_BSR SEQ_BASE movf SEQ_RANDOM_SEED_L, W, BANKED mulwf SEQ_RANDOM_SEED_H, BANKED movf TMR0L, W addwf PRODL, W movwf SEQ_RANDOM_SEED_L, BANKED movlw 0x69 addwfc PRODH, W movwf SEQ_RANDOM_SEED_H, BANKED returnHow do I define this as an assembler function that I can reference in C? I could not find a mixed C/Assembler example project.Many thanks, ALEXander.
TK. Posted August 25, 2008 Report Posted August 25, 2008 Hi Alexander,did you really search for examples?Here you will find a lot of examples for accessing assembler code from C with a wrapper:http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fmodules%2FThis example is a bit more simple, only one file which references (and contains) the assembly code:http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fexamples%2Fsm_c_example1%2FThe mclock.c file of this application demonstrates, how to use inline assembly code:http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fclockbox%2Fenhanced%2FBest Regards, Thorsten.
wackazong Posted August 25, 2008 Author Report Posted August 25, 2008 Thanks, I only looked in the base package and did not find an app where I could really understand what was going on.
stryd_one Posted August 25, 2008 Report Posted August 25, 2008 Don't forget the wiki - there is a whole section devoted to this subject at http://www.midibox.org/dokuwiki/how_to_mix_c_and_asm. At the moment, it's very bare, although it links to a very informative forum post. Perhaps you'll flesh it out a little when you finish your work? :)
wackazong Posted September 1, 2008 Author Report Posted September 1, 2008 OK, I got it working. I generated a simple application sceleton which uses a c and an asm part, and links them both together. so far, only one byte is supported for parameters or return values. anybody care? I will extend it soon.Best, ALEXander.BTW: is SET_BSR "Set the Bank Select Register"? Took me a while to figure that one out. But now it works.
TK. Posted September 2, 2008 Report Posted September 2, 2008 yes, SET_BSR is a macro which simplifies the usage of movlb, see also:http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Finclude%2Fasm%2Fmacros.hBest Regards, Thorsten.
stryd_one Posted September 13, 2008 Report Posted September 13, 2008 I generated a simple application sceleton which uses a c and an asm part, and links them both together.Would be cool if you could show the various ways of doing it... Functions, variables, inline, included, via modules, etc
