What is a "monolithic" capacitor??
Hello guys,
I am dutch and i can't seem to find a translation for monolithic capacitor, can someone explain to me what the difference is between a ceramic capacitor and a monolithic capacitor? also what happens if you use a ceramic capacitor instead of a monolithic capacitor. I'm a little lost here, looked on the internet but can't find anything.
grtz
Google seems to have confirmed my suspicion that monolithic refers to the method of construction, rather than the material used.... not sure whether a monolithic ceramic is interchangeable with a (not-monolithic) ceramic though?
The capacitors I buy which are called "monolithic" are ceramic, they are not flat and round like most ceramic capacitors, they're usually a shiny blob and much smaller than other kinds of capacitors. In most cases, there's nothing special about it being "monolithic" (other than the small size) so you could substitute with a normal ceramic or polyester capacitor.
Thanks W! Now I know the type you mean....
I hear if you touch it with your finger it gives you special powers
Do you have a pinout for that one?
lol, thanks for the reply's.
I'm happy that it is the same as a ceramic, cause otherwise i could desolder them all :D
Greetz
  • 3 weeks later...
Greetz
I ran into this issue as well, not knowing the difference. I'm putting together a BOM for the MB-6582 and am following Wilba's part list. I have learned what Wilba had elaborated on. It mainly comes down to form factor ( niLS shoot me.)
mono
adjective
1. designating sound transmission or recording or reproduction over a single channel
noun
1. an acute disease characterized by fever and swollen lymph nodes and an abnormal increase of mononuclear leucocytes or monocytes in the bloodstream; not highly contagious; some believe it can be transmitted by kissing [syn: infectious mononucleosis]
Lithic
Lith"ic\, a. [Gr. ? of or belonging to stones, fr. li`qos stone: cf. F. lithique.]
1. Of or pertaining to stone; as, lithic architecture.
2. (Med.) Pertaining to the formation of uric-acid concretions (stone) in the bladder and other parts of the body; as, lithic diathesis.
Oh, that might not be a wanted side effect...
(?män·??lith·ik s??ram·ik k??pas·?d·?r)
(electronics) A capacitor that consists of thin dielectric layers interleaved with staggered metal-film electrodes; after leads are connected to alternate projecting ends of the electrodes, the assembly is compressed and sintered to form a solid monolithic block.  :D that's more like it!
Well, the form factor is a side-effect of the method of construction. The name refers to the method of construction.
