how to build a -2,6 v (lcd negative contrast )with the 5v core psu
Hi,all,i am looking for a shematic to build a -2,6 v(lcd negative contrast ) with the 5v core psu,thanks
I 've a made a newbie error when i 've ordered my 2 lcd at voti..be careful lcd 14 is not the must, take lcd 22 Boops
The LCD derives its contrast voltage using a pot (P2) connected across +5V and GND (Vdd and Vss). The wiper of the pot is then connected to the Vo Contrast pin on your LCD.
Normally LCD contrast voltages are in the range 2V - 3.5V.
To get -2.6v, build the circuit linked by Ping, and wire your pot (P2) across -5V and GND. The wiper of the pot connects to Vo as normal.
Be sure to disconnect the +5V terminal of your pot before connecting it to -5V, to avoid smoke...
hi,i do the job... :o  it works ;magic electronic!!! An advice: put the trim p2 on a separate veroboard with the IC 7660 and Caps; be careful with the caps polarity and put off the 18F452...now i attack the opl3 -core connections  :P Good night and best regards .
[me=stryd_one]does the "it's working" dance[/me]
boops I hope you can share more details of your solution... you're not the first to have this problem, and I'm sure others will be in the same situation again  ;)
more explanations:
-printed the shema with the IC 7660 ,and caps
-buy the parts,don't forget the ic socket for the 7660 (or equivalent)
-pull off the ics of the core
-cut a little piece of veroboard and make a hole (3mm)to install on one hole of the core pcb
-desolder with (pompe a dessouder) the P2 (trim on the right on the core,which control the contrast)
-build the shematic http://www.modthebox.com/lcdhowto.shtml be careful with caps polarity ,take the +5v and ground on the core where the P2 was soldered,test short cuts,and polarity ,you should have -5v beetween ground and pin 5 of the ic 7660
-ok ,courage ,now solder the P2 on the little veroboard and see the  shematic below:
-control the negative voltage with the P2 trim..
                            BRAVO      Boop's
3684_img023_jpg80bf1c498068ba78fbff7da25
