This N°9 Posted October 24, 2008 Report Posted October 24, 2008 hello,I try to connect a bank stick to IIC-port and a character LCD to J15. When the Bankstick is notconnected, everything runs fine, if the stick is connected, the LCD won't work anymore, but the application is running normal.I did not yet check if Bankstick reads/writes work.Is it a problem to have a bankstick and character LCDconnected at the same time?PIN 28 of the PIC is used for both IIC and LCD port. What is its function?thanks, this Quote
stryd_one Posted October 25, 2008 Report Posted October 25, 2008 http://www.midibox.org/dokuwiki/mios_pin_listThe pin is shared but that's OK :)I wonder if this is related to your other issue....http://www.midibox.org/forum/index.php/topic,12379.0/topicseen.html#msg103103 Quote
This N°9 Posted October 25, 2008 Author Report Posted October 25, 2008 hmm... I think no. I just disconnected the SRIO boards, the problemstays. the DOUT-issue is not a malfunction in this way, it's just kindof confusing.. the test app works as expected, only the MSB/LSB ofthe DOUT-registers are swapped. the single registers appear in theright order.. and with the ribbon cable wiring you have very fewpontential wiring bug sources :-)I'll check the Bankstick wiring, maybe some solder-bridge or something(as I already had on a core PCB this mornig..)some more pics.. Quote
This N°9 Posted October 25, 2008 Author Report Posted October 25, 2008 problem solved....me idiot made a shortcut with the mounting screws for thelittle bankstick-bord..but the DOUT-issue still remains. Quote
TK. Posted October 25, 2008 Report Posted October 25, 2008 but the DOUT-issue still remains.It already has been answered here:http://www.midibox.org/forum/index.php/topic,12379.msg103109.html#msg103109For your own comfort: don't start double posts!Best Regards, Thorsten. Quote
