This N°9 Posted October 27, 2008 Posted October 27, 2008 hi,I have some question concerning bankstick MIOS_Bankstick_WritePage:- does the function return immediately and the 64 bytes are written in background, or do I have to check for a flag or something until I can call the function again? is the MIOS_BOX_STAT.BS_AVAILABLE the magic flag which I have to poll after each writepage?why I'am asking: In my application I have a current_preset - array (size 64 bytes)and a function that writes it to the stick with MIOS_BANKSTICK_WritePage. IfI write the preset to any preset-storage-address (preset_num << 6),everything works fine. But if I call the same store-function in a loop to initall the 16 presets on the stick, I get very strange results.. I do this in the main-loop (USER_Tick).if I just init one preset, all works fine again.- what's the point about the 'verifiy' - option, when/what for do I need it or not? is the verify for writepage done for every byte, or do I just get an error when the whole content is equal?thanks,this
TK. Posted October 27, 2008 Posted October 27, 2008 MIOS_Bankstick_WritePage is a blocking function, you can be sure that the programming process has finished when the function is exit.See also this programming example.You have to ensure, that no IRQ routine accesses the BankStick while it is accessed from the "main" program, of course... regardless if the content is read or written."Verify" just reads and compares the written content. I used it in the early days to doublecheck if BankStick writes are reliable. They are - therefore I mostly disable it in my own application meanwhile.Best Regards, Thorsten.
This N°9 Posted October 28, 2008 Author Posted October 28, 2008 ok, I found it:it's about the building of the storage-address. wrong use of bitshift leads tointeresting results (different if I call the same code from Tick or from DIN_Notify...):this works not (I inserted some LCD code to get a debug output):void preset_store(unsigned char num) __wparam{ unsigned int addr = ((unsigned int)num) << 6; //unsigned int addr = num*64; MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0); MIOS_LCD_PrintBCD2(num); MIOS_LCD_PrintCString(" - "); MIOS_LCD_PrintBCD5(addr); MIOS_BANKSTICK_WritePage(addr, current_preset); } output for num==10 when I call it in DIN_NotifyToggle: 10 - 64 and for calls from Tick: 10 - 0 this one works: void preset_store(unsigned char num) __wparam{ unsigned int addr = num; addr <<= 6; MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0); MIOS_LCD_PrintBCD2(num); MIOS_LCD_PrintCString(" - "); MIOS_LCD_PrintBCD5(addr); MIOS_BANKSTICK_WritePage(addr, current_preset); } 10 - 640 2 - 128 etc. but this works NOT!!: void preset_store(unsigned char num) __wparam{ unsigned int addr = num; //addr <<= 6; MIOS_BANKSTICK_WritePage(addr << 6, current_preset); } finally, this variant works: void preset_store(unsigned char num) __wparam{ unsigned int addr = num; addr <<= 6; MIOS_BANKSTICK_WritePage(addr, current_preset); } it took me hours to come to this ;-)
stryd_one Posted October 28, 2008 Posted October 28, 2008 it took me hours to come to this ;-)I bet it did!SDCC is *really* picky about parentheses... Can you try these? I've commented my changes.However... it behaving differently when called from the tick or notify functions, is really strange... And really, they all should work. What version of SDCC are you using? Can you do 'sdcc -v' and paste the output?It kinda seems like an SDCC bug...void preset_store(unsigned char num) __wparam{ unsigned int addr = (((unsigned int)num) << 6); // parentheses added here //unsigned int addr = num*64; MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0); MIOS_LCD_PrintBCD2(num); MIOS_LCD_PrintCString(" - "); MIOS_LCD_PrintBCD5(addr); MIOS_BANKSTICK_WritePage(addr, current_preset); } void preset_store(unsigned char num) __wparam{ unsigned int addr = ((unsigned char)num); // Typecast added here //addr <<= 6; MIOS_BANKSTICK_WritePage((addr << 6), current_preset); // parentheses here }Edit: I'd love to see the output asm if you still have it handy! (yes, I can make it myself, but i'm busy :( )
This N°9 Posted October 29, 2008 Author Posted October 29, 2008 Can you do 'sdcc -v' and paste the output?here it is:this@this-laptop:~$ sdcc -vSDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.7.0 #4 818 (Jan 18 2008) (UNIX)MIOS_BANKSTICK_WritePage((addr << 6), current_preset); // parentheses herethis one I already tried, makes no difference.However... it behaving differently when called from the tick or notify functions, is really strange... And really, they all should work.I'dont exactly know where notify is called, but I think it's from a timer - callback, not from the main-loop? This could make the difference.It kinda seems like an SDCC bug...could be. I'll study the sdcc-manual once more, there are specials about passing parameters to functions etc. I could imagine that bit-shifts have specialthings to take are about too.I'd love to see the output asm if you still have it handy!ok, i start with the current, woking version: ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 162; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 163; main.c unsigned int addr = num; CLRF r0x01 ; .line 164; main.c addr <<= 6; RRCF r0x01, F RRCF r0x00, F RRCF r0x01, F RRCF r0x00, F RRCF r0x01, W ANDLW 0xc0 XORWF r0x00, W XORWF r0x00, F XORWF r0x00, W MOVWF r0x01 ; .line 165; main.c MIOS_BANKSTICK_WritePage(addr, current_preset); MOVLW HIGH(_current_preset) MOVWF r0x03 MOVLW LOW(_current_preset) MOVWF r0x02 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x02, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x00, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN your first proposition (Debug - Output: num==6 -> addr==64): NOT working: ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 170; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 171; main.c unsigned int addr = (((unsigned int)num) << 6); // parentheses added here CLRF r0x01 RRCF r0x01, W MOVWF r0x03 RRCF r0x02, W MOVWF r0x02 RRCF r0x03, F RRCF r0x02, F RRCF r0x03, W ANDLW 0xc0 XORWF r0x02, W XORWF r0x02, F XORWF r0x02, W MOVWF r0x03 ; .line 177; main.c MIOS_BANKSTICK_WritePage(addr, current_preset); MOVLW HIGH(_current_preset) MOVWF r0x01 MOVLW LOW(_current_preset) MOVWF r0x00 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x00, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x02, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN your second proposition (Debug - Output: num==6 -> addr==348): this one works only if I have the debug code uncommented (!). the funny thing is, that the debug output is correct too. If the shift would appear after passing the value, this would not be the case. so this one WORKS: ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 170; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 171; main.c unsigned int addr = ((unsigned char)num); MOVFF r0x00, r0x01 CLRF r0x02 ; .line 172; main.c MIOS_LCD_Clear(); CALL _MIOS_LCD_Clear ; .line 173; main.c MIOS_LCD_CursorSet(0); MOVLW 0x00 CALL _MIOS_LCD_CursorSet ; .line 174; main.c MIOS_LCD_PrintBCD2(num); MOVF r0x00, W CALL _MIOS_LCD_PrintBCD2 ; .line 175; main.c MIOS_LCD_PrintCString(" - "); MOVLW UPPER(__str_0) MOVWF POSTDEC1 MOVLW HIGH(__str_0) MOVWF POSTDEC1 MOVLW LOW(__str_0) CALL _MIOS_LCD_PrintCString MOVLW 0x02 ADDWF FSR1L, F ; .line 176; main.c MIOS_LCD_PrintBCD5((addr << 6));// parentheses here RRCF r0x02, W MOVWF r0x03 RRCF r0x00, W MOVWF r0x00 RRCF r0x03, F RRCF r0x00, F RRCF r0x03, W ANDLW 0xc0 XORWF r0x00, W XORWF r0x00, F XORWF r0x00, W MOVWF r0x03 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x00, W CALL _MIOS_LCD_PrintBCD5 INCF FSR1L, F ; .line 177; main.c MIOS_BANKSTICK_WritePage((addr << 6), current_preset);// parentheses here MOVLW HIGH(_current_preset) MOVWF r0x02 MOVLW LOW(_current_preset) MOVWF r0x01 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x02, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x00, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN ..while this one is NOT working!! : ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 170; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 171; main.c unsigned int addr = ((unsigned char)num); CLRF r0x01 ; .line 177; main.c MIOS_BANKSTICK_WritePage((addr << 6), current_preset);// parentheses here RRCF r0x01, W MOVWF r0x03 RRCF r0x02, W MOVWF r0x02 RRCF r0x03, F RRCF r0x02, F RRCF r0x03, W ANDLW 0xc0 XORWF r0x02, W XORWF r0x02, F XORWF r0x02, W MOVWF r0x03 MOVLW HIGH(_current_preset) MOVWF r0x01 MOVLW LOW(_current_preset) MOVWF r0x00 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x00, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x02, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN the typecast on assign nor the parentheses on passing make any difference. this one works again: ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 170; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 171; main.c unsigned int addr = num; MOVFF r0x00, r0x01 CLRF r0x02 ; .line 172; main.c MIOS_LCD_Clear(); CALL _MIOS_LCD_Clear ; .line 173; main.c MIOS_LCD_CursorSet(0); MOVLW 0x00 CALL _MIOS_LCD_CursorSet ; .line 174; main.c MIOS_LCD_PrintBCD2(num); MOVF r0x00, W CALL _MIOS_LCD_PrintBCD2 ; .line 175; main.c MIOS_LCD_PrintCString(" - "); MOVLW UPPER(__str_0) MOVWF POSTDEC1 MOVLW HIGH(__str_0) MOVWF POSTDEC1 MOVLW LOW(__str_0) CALL _MIOS_LCD_PrintCString MOVLW 0x02 ADDWF FSR1L, F ; .line 176; main.c MIOS_LCD_PrintBCD5(addr << 6);// parentheses here RRCF r0x02, W MOVWF r0x03 RRCF r0x00, W MOVWF r0x00 RRCF r0x03, F RRCF r0x00, F RRCF r0x03, W ANDLW 0xc0 XORWF r0x00, W XORWF r0x00, F XORWF r0x00, W MOVWF r0x03 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x00, W CALL _MIOS_LCD_PrintBCD5 INCF FSR1L, F ; .line 177; main.c MIOS_BANKSTICK_WritePage(addr << 6, current_preset);// parentheses here MOVLW HIGH(_current_preset) MOVWF r0x02 MOVLW LOW(_current_preset) MOVWF r0x01 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x02, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x00, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN ...and this one is NOT working: ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 170; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 171; main.c unsigned int addr = num; CLRF r0x01 ; .line 177; main.c MIOS_BANKSTICK_WritePage(addr << 6, current_preset);// parentheses here RRCF r0x01, W MOVWF r0x03 RRCF r0x02, W MOVWF r0x02 RRCF r0x03, F RRCF r0x02, F RRCF r0x03, W ANDLW 0xc0 XORWF r0x02, W XORWF r0x02, F XORWF r0x02, W MOVWF r0x03 MOVLW HIGH(_current_preset) MOVWF r0x01 MOVLW LOW(_current_preset) MOVWF r0x00 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x00, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x02, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN one more.. this is not working : ; ; Starting pCode block S_main__preset_store code _preset_store: ; .line 163; main.c void preset_store(unsigned char num) __wparam{ MOVFF FSR2L, POSTDEC1 MOVFF FSR1L, FSR2L MOVFF r0x00, POSTDEC1 MOVFF r0x01, POSTDEC1 MOVFF r0x02, POSTDEC1 MOVFF r0x03, POSTDEC1 MOVFF r0x04, POSTDEC1 MOVWF r0x00 ; .line 164; main.c unsigned int addr = num; CLRF r0x01 ; .line 166; main.c MIOS_BANKSTICK_WritePage((addr <<= 6), current_preset); RRCF r0x01, W MOVWF r0x03 RRCF r0x02, W MOVWF r0x02 RRCF r0x03, F RRCF r0x02, F RRCF r0x03, W ANDLW 0xc0 XORWF r0x02, W XORWF r0x02, F XORWF r0x02, W MOVWF r0x03 MOVLW HIGH(_current_preset) MOVWF r0x01 MOVLW LOW(_current_preset) MOVWF r0x00 MOVLW 0x80 MOVWF r0x04 MOVF r0x04, W MOVWF POSTDEC1 MOVF r0x01, W MOVWF POSTDEC1 MOVF r0x00, W MOVWF POSTDEC1 MOVF r0x03, W MOVWF POSTDEC1 MOVF r0x02, W CALL _MIOS_BANKSTICK_WritePage MOVLW 0x04 ADDWF FSR1L, F MOVFF PREINC1, r0x04 MOVFF PREINC1, r0x03 MOVFF PREINC1, r0x02 MOVFF PREINC1, r0x01 MOVFF PREINC1, r0x00 MOVFF PREINC1, FSR2L RETURN so It looks like the bitshift needs to beon a separate line.. I let it be your job to interpret the asm..
This N°9 Posted October 29, 2008 Author Posted October 29, 2008 cocerning bitshift, I only found this in the SDCC-manual:8.1.8 Bit-shifting Operations.Bit shifting is one of the most frequently used operation in embedded programming. SDCC tries to implementbit-shift operations in the most ef?cient way possible, e.g.: unsigned char i; ... i > >= 4; ...generates the following code: mov a,_i swap a anl a,#0x0f mov _i,aIn general SDCC will never setup a loop if the shift count is known. Another example: unsigned int i; ... i > >= 9; ...will generate: mov a,(_i + 1) mov (_i + 1),#0x00 clr c rrc a mov _i,a8.1.9 Bit-rotationA special case of the bit-shift operation is bit rotation, SDCC recognizes the following expression to be a leftbit-rotation: unsigned char i; /* unsigned is needed for rotation */ ... i = ((i < < 1) | (i > > 7)); ...will generate the following code: mov a,_i rl a mov _i,aSDCC uses pattern matching on the parse tree to determine this operation.Variations of this case will also berecognized as bit-rotation, i.e.: i = ((i > > 7) | (i < < 1)); /* left-bit rotation */
stryd_one Posted October 29, 2008 Posted October 29, 2008 Yeh, I think the only part of the manual that really applies here, is the part where they say something about chars not being promoted to int for arithmetic (as they usually are). I think it's in the compliance section? SDCC : mcs51/gbz80/z80/avr/ds390/pic16/pic14/TININative/xa51/ds400/hc08 2.7.0 #4 Still haven't upgraded to 2.8? You should. I'm sure I told you about this last time ;)I'dont exactly know where notify is called, but I think it's from a timer - callback, not from the main-loop? This could make the difference.Memory is saved and restored in ISR's anyway, but it's called from a flag. this one works only if I have the debug code uncommented (!).Optimizer bug. so It looks like the bitshift needs to beon a separate line.. Well, putting it in parentheses should do the same thing, that's why it's weird.So, more and more, it's looking like an SDCC bug, So I figure, "I wonder if my latest SDCC build does the same thing?" well guess what I get: error: multiple sections using address 0 Here's the code that produced it: // $Id: main.c 333 2008-05-10 20:49:56Z tk $ /* * MIOS SDCC Wrapper * * ========================================================================== * * Copyright (C) <year> <name> (<email>) * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <cmios.h> #include <pic18fregs.h> unsigned char testval; unsigned char current_preset[64] = {8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8,8}; void preset_storeb(unsigned char num) __wparam{ unsigned int addr = num; addr <<= 6; MIOS_BANKSTICK_WritePage(addr, current_preset); } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after startup to initialize the // application ///////////////////////////////////////////////////////////////////////////// void Init(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS in the mainloop when nothing else is to do ///////////////////////////////////////////////////////////////////////////// void Tick(void) __wparam { preset_storeb(testval); } ///////////////////////////////////////////////////////////////////////////// // This function is periodically called by MIOS. The frequency has to be // initialized with MIOS_Timer_Set ///////////////////////////////////////////////////////////////////////////// void Timer(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when the display content should be // initialized. Thats the case during startup and after a temporary message // has been printed on the screen ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Init(void) __wparam { MIOS_LCD_Clear(); MIOS_LCD_CursorSet(0x00); MIOS_LCD_PrintCString("Hello World!"); } ///////////////////////////////////////////////////////////////////////////// // This function is called in the mainloop when no temporary message is shown // on screen. Print the realtime messages here ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Tick(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a complete MIDI event has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { testval = evnt0; } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has been received // which has been specified in the MIOS_MPROC_EVENT_TABLE ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has not been completly // received within 2 seconds ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyTimeout(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI byte has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedByte(unsigned char byte) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS before the shift register are loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Prepare(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after the shift register have been loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Finish(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an button has been toggled // pin_value is 1 when button released, and 0 when button pressed ///////////////////////////////////////////////////////////////////////////// void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an encoder has been moved // incrementer is positive when encoder has been turned clockwise, else // it is negative ///////////////////////////////////////////////////////////////////////////// void ENC_NotifyChange(unsigned char encoder, char incrementer) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a pot has been moved ///////////////////////////////////////////////////////////////////////////// void AIN_NotifyChange(unsigned char pin, unsigned int pin_value) __wparam { } ARGH!!I never saw this error before you joined ;)
This N°9 Posted October 29, 2008 Author Posted October 29, 2008 Still haven't upgraded to 2.8? You should. I'm sure I told you about this last timeyes, I know.. but currently I'm using the Ubuntu dist, and I'am lazy. I shouldbuild it from the source..Memory is saved and restored in ISR's anyway, but it's called from a flag. hm.. called from a flag? what's this?Well, putting it in parentheses should do the same thing, that's why it's weird.I'am really a asm-analphabet, you don't see anything that could explain this in the asm-code?error: multiple sections using address 0you get this on compiling? I can compile your test-code without any problems.. maybeI shouldn't update my sdcc... :-)this@this-laptop:~/mios/trunk/apps/this_testapp$ make rm -rf _output/* rm -rf _output rm -rf *.cod *.map *.lst rm -rf *.hex mkdir -p _output /bin/bash /home/this/mios/trunk/bin/mios-gpasm -c -p p18f452 -I./src -I /home/this/mios/trunk/include/asm -I /home/this/mios/trunk/include/share -I /home/this/mios/trunk/modules/app_lcd/dummy -DDEBUG_MODE=0 -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/this/mios/trunk/modules/mios_wrappe r /home/this/mios/trunk/modules/mios_wrapper/mios_wrapper.asm -o _output/mios_wrapper.o /bin/bash /home/this/mios/trunk/bin/mios-gpasm -c -p p18f452 -I./src -I /home/this/mios/trunk/include/asm -I /home/this/mios/trunk/include/share -I /home/this/mios/trunk/modules/app_lcd/dummy -DDEBUG_MODE=0 /home/this/mios/trunk/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o /bin/bash /home/this/mios/trunk/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --oban ksel=2 -I./src -I /home/this/mios/trunk/include/c -I /home/this/mios/trunk/include/share -DDEBUG_MODE=0 main.c -o _output/main.o /home/this/mios/trunk/bin/mios-gpasm modifies _output/main.asm, result in _output/main__mios-gpasm-tmp.asm gplink -s /home/this/mios/trunk/etc/lkr/p18f452.lkr -m -o project.hex /home/this/mios/trunk/lib/libsdcc.lib /home/this/mios/trunk/lib/pic18f452.li b _output/mios_wrapper.o _output/app_lcd.o _output/main.o ARGH!!I never saw this error before you joinedsome people could hate me for this property :-)
This N°9 Posted October 30, 2008 Author Posted October 30, 2008 error: multiple sections using address 0I updated to the version 2.8.4 of SDCC, now I get the same error as you *arghhh*.besides, I have to do a typecast on passing the address of my array now:MIOS_BANKSTICK_ReadPage(addr,current_preset);-->main.c:105: error 78: incompatible typesI have to write:MIOS_BANKSTICK_ReadPage(addr,(char*)current_preset);...and the compiler option --optimize-goto is no more present in 2.8.4:at 1: warning 117: unknown compiler option '--optimize-goto' ignoredAt the base of your test-code, I will analyze what causes the "error: multiple sections using address 0"seems to be the linker that throws it:make rm -rf _output/* rm -rf _output rm -rf *.cod *.map *.lst rm -rf *.hex mkdir -p _output /bin/bash /home/this/mios/trunk/bin/mios-gpasm -c -p p18f452 -I./src -I /home/this/mios/trunk/include/asm -I /home/this/mios/trunk/include/share -I /home/this/mios/trunk/modules/app_lcd/dummy -DDEBUG_MODE=0 -DSTACK_HEAD=0x37f -DSTACK_IRQ_HEAD=0x33f -I /home/this/mios/trunk/modules/mios_wrapper /home/this/mios/trunk/modules/mios_wrapper/mios_wrapper.asm -o _output/mios_wrapper.o /bin/bash /home/this/mios/trunk/bin/mios-gpasm -c -p p18f452 -I./src -I /home/this/mios/trunk/include/asm -I /home/this/mios/trunk/include/share -I /home/this/mios/trunk/modules/app_lcd/dummy -DDEBUG_MODE=0 /home/this/mios/trunk/modules/app_lcd/dummy/app_lcd.asm -o _output/app_lcd.o /bin/bash /home/this/mios/trunk/bin/mios-sdcc -c -mpic16 -p18f452 --fommit-frame-pointer --optimize-goto --optimize-cmp --disable-warning 85 --obanksel=2 -I./src -I /home/this/mios/trunk/include/c -I /home/this/mios/trunk/include/share -DDEBUG_MODE=0 main.c -o _output/main.o at 1: warning 117: unknown compiler option '--optimize-goto' ignored gplink -s /home/this/mios/trunk/etc/lkr/p18f452.lkr -m -o project.hex /home/this/mios/trunk/lib/libsdcc.lib /home/this/mios/trunk/lib/pic18f452.lib _output/mios_wrapper.o _output/app_lcd.o _output/main.o error: multiple sections using address 0 make: *** [project.hex] Fehler 1 If I can't fix it, I'll go back to the old SDCC that works for me..
This N°9 Posted October 30, 2008 Author Posted October 30, 2008 @stryd_oneerror: multiple sections using address 0I modified your testapp (just this line):MIOS_BANKSTICK_ReadPage(addr,current_preset);//-->error: multiple sections using address 0MIOS_BANKSTICK_ReadPage(0x00,current_preset);//-->error: multiple sections using address 0MIOS_BANKSTICK_ReadPage(addr,0);//-->error: multiple sections using address 0MIOS_BANKSTICK_ReadPage(0x00,0);//-->no error, compliles and linksthe error occurs also if I never call "preset_storeb". I switched back from SDCC 2.8.4 to the official Kubuntu package 2.7.0, this onecomplies my app, and it works without problems on my MIDI-box.
stryd_one Posted October 31, 2008 Posted October 31, 2008 Yerr, something has gotta be up with my toolchain. I must've killed it with new toolchain. My apologies. I'll fix it up this weekend and be more helpful.
This N°9 Posted November 1, 2008 Author Posted November 1, 2008 maybe the SDCC 2.8.4 need another gputils dist?
stryd_one Posted November 3, 2008 Posted November 3, 2008 Got the latest GPUtils on here too.... No joy.Gonna work on making these two toolchains play nicely together and see how I go.
This N°9 Posted November 3, 2008 Author Posted November 3, 2008 I just tried to search on google for similar threads, and found this:http://osdir.com/ml/compilers.sdcc.user/2007-10/msg00030.htmlthey talk about interrupt handlers, I did not read it really carefully,because I'am tired and have to to to bed, It's just a quick shot try,maybe there's some usefull info.In my example the error occurs on calling MIOS_BANKSTICK_ReadPagewith some var param, so maybe there's something in the MIOS kernelthat was accepted or ignored or interpreted differently by the olderSDCC compiler?
stryd_one Posted November 16, 2008 Posted November 16, 2008 Yep, compiler error. My toolchain was screwy but that was my fault (I broke it and I knew that) but once it was fixed, the above code *all* works with sdcc 2.8.0. However, 2.8.4 (the snapshot) is no good. Grab the working one here: sdcc-2.8.0-setup.exeWould you like to file the bug report?
This N°9 Posted November 18, 2008 Author Posted November 18, 2008 Would you like to file the bug report?sorry, I don't understand this wording. If you explain it tome I'll do it :-)
stryd_one Posted November 18, 2008 Posted November 18, 2008 This is what I meant:https://sourceforge.net/tracker/index.php?func=detail&aid=2308409&group_id=599&atid=100599 ;)
This N°9 Posted November 18, 2008 Author Posted November 18, 2008 Ok, I see. I think we should not mix up the bitshift - subject with the "error: multiple sections using address 0" subject. The latterappears also with no bitshift at all.MIOS_BANKSTICK_ReadPage(addr,current_preset);//-->error: multiple sections using address 0 MIOS_BANKSTICK_ReadPage(0x00,current_preset);//-->error: multiple sections using address 0 MIOS_BANKSTICK_ReadPage(addr,0);//-->error: multiple sections using address 0 MIOS_BANKSTICK_ReadPage(0x00,0);//-->no error, compliles and links It seems like the parameter passing (and all that follows) causes the problem.And maybe all the MIOS - environment is needed to reproduce the problem.I will take your test-application and make a distribution, which I can post as a standalone-package for the SDCC - developpers to (hopefully) reproduce the issue.
stryd_one Posted November 19, 2008 Posted November 19, 2008 The latter appears also with no bitshift at all.With 2.8.0 ? I didn't see that myself... Anyway, as I said in the bug report, I had seen this behaviour in other code but had not been able to narrow it down... So I'm not singling this out to be a bitshift-related error, that's just one example of how to reproduce the error. If you can provide further examples to them, that can only help :)
This N°9 Posted November 20, 2008 Author Posted November 20, 2008 With 2.8.0 ?no, this was with 2.8.4. now I'am a bit confused, because you write the code compliled & linked with 2.8.0 ?is there also a problem with 2.8.0 ? Insert Quote@stryd_oneQuoteerror: multiple sections using address 0I modified your testapp (just this line):MIOS_BANKSTICK_ReadPage(addr,current_preset);//-->error: multiple sections using address 0MIOS_BANKSTICK_ReadPage(0x00,current_preset);//-->error: multiple sections using address 0MIOS_BANKSTICK_ReadPage(addr,0);//-->error: multiple sections using address 0MIOS_BANKSTICK_ReadPage(0x00,0);//-->no error, compliles and linksthe error occurs also if I never call "preset_storeb".I switched back from SDCC 2.8.4 to the official Kubuntu package 2.7.0, this onecomplies my app, and it works without problems on my MIDI-box.
stryd_one Posted November 20, 2008 Posted November 20, 2008 no, this was with 2.8.4. now I'am a bit confused, because you write the code compliled & linked with 2.8.0 ?Exactly - 2.8.0 is good. 2.8.4 is a snapshot build with bugs like the one you posted above. 2.7.0 is OK, but has other bugs, what with being an older version and all.
This N°9 Posted November 21, 2008 Author Posted November 21, 2008 ok, so I will pack the test application with the modifiedlines and the comments and post it to the bug report.2.8.4 is the compiler version that caused the linkererror then.
This N°9 Posted November 21, 2008 Author Posted November 21, 2008 ok, I cooked the shit down, a can confirm that with 2.8.0 everthing works fine.2.8.5, the latest snapshot, causes the problems. check this sample code (check code in init & read comments):// $Id: main.c 333 2008-05-10 20:49:56Z tk $ /* * MIOS SDCC Wrapper * * ========================================================================== * * Copyright (C) <year> <name> (<email>) * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <cmios.h> #include <pic18fregs.h> unsigned char current_preset[64]; const unsigned char current_preset_const[64]= { 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8, 8,8,8,8,8 }; ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after startup to initialize the // application ///////////////////////////////////////////////////////////////////////////// void Init(void) __wparam{ unsigned int addr = 0x20; //the comments after the code lines apply with sdcc 2.8.4 / 2.8.5 -- //with sdcc 2.8.0 all the lines compile & link without any problems MIOS_BANKSTICK_WritePage(addr, (char*)current_preset);// -> linker error error: multiple sections using address 0 MIOS_BANKSTICK_WritePage(0x10, (char*)current_preset);// -> linker error error: multiple sections using address 0 MIOS_BANKSTICK_WritePage(addr,&(current_preset[0]));// -> linker error error: multiple sections using address 0 MIOS_BANKSTICK_WritePage(addr,0);//compiles & links MIOS_BANKSTICK_WritePage(addr,(char*)current_preset_const);//compiles and links. address to const in codespace } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS in the mainloop when nothing else is to do ///////////////////////////////////////////////////////////////////////////// void Tick(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is periodically called by MIOS. The frequency has to be // initialized with MIOS_Timer_Set ///////////////////////////////////////////////////////////////////////////// void Timer(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when the display content should be // initialized. Thats the case during startup and after a temporary message // has been printed on the screen ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Init(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called in the mainloop when no temporary message is shown // on screen. Print the realtime messages here ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Tick(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a complete MIDI event has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has been received // which has been specified in the MIOS_MPROC_EVENT_TABLE ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has not been completly // received within 2 seconds ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyTimeout(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI byte has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedByte(unsigned char byte) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS before the shift register are loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Prepare(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after the shift register have been loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Finish(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an button has been toggled // pin_value is 1 when button released, and 0 when button pressed ///////////////////////////////////////////////////////////////////////////// void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an encoder has been moved // incrementer is positive when encoder has been turned clockwise, else // it is negative ///////////////////////////////////////////////////////////////////////////// void ENC_NotifyChange(unsigned char encoder, char incrementer) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a pot has been moved ///////////////////////////////////////////////////////////////////////////// void AIN_NotifyChange(unsigned char pin, unsigned int pin_value) __wparam { } I made two release packages, one I compliled with 2.8.0, one with 2.8.5. so allthat is needed to analyze the problem is included. The problem has nothing todo with bitshift-issues.It's interesting that when addressing a const array, the linker does not complain,but when addressing a variable 64-char-array, it throws the error. I removed everything that is not really necessary to cook down the problem. there isa 64 byte var array, and a 64 byte const array, all other stuff happens infunction "init". I added a file named SHELL.txt to the failing release packagewhich contains the shell output of the make-command.@stryd_one:I just commented the bug report with the files attached to this post. Itnow appears as follow-up to your bug-report on the sourceforge-site.I hope this will help.-test_sdcc.2.8.0.tar.bz2.ziptest_sdcc.2.8.5.tar.bz2.ziptest_sdcc.2.8.0.tar.bz2.ziptest_sdcc.2.8.5.tar.bz2.zip
This N°9 Posted November 24, 2008 Author Posted November 24, 2008 It did help... this was a Makefile - issue:http://sourceforge.net/tracker/?func=detail&atid=100599&aid=2308409&group_id=599
stryd_one Posted November 24, 2008 Posted November 24, 2008 Well no, not really a makefile issue at all...it was an issue where SDCC was broken... twice actually.The first break was that the --asm parametr was completely ignored. That was an accident.That was done attemting to "fix" sdcc, so that it would accept bad paths (which were illegal in windows, maybe *nix too), which, even if you ignore the first, accidental 'break', additionally broke sdcc for perfectly good makefiles, like ours.No need to alter our makefile here, as Raphael has wisely returned sdcc to it's old behaviour.It kinda seems like an SDCC bug...Been here, done this before ;)It's important to realise that SDCC is heavily developed, so bugs can appear and be fixed very regularly. If you're using a nightly build, you have to watch out for new bugs, and if you're using a release build, then you should use the latest one available. That's why I told you a few times before this thread to update to 2.8 ;)Edit: gotta wait till tomorrow for the new windoze snapshot. How's it work on *nix?
