single 128X64 KS0108 for the lc ?
Hi all gurus (i am not .. :( )
is a single 128X64 KS0108 is suitable for an LC midibox (i have read that fonts size can be reduce) ?
and is there a possiblity to switch the sel button to mute,rec,solo, ... with another button like with LcXmu software (http://www.opuslocus.com/lcxmu)
if yes modification in the src for the lc would be difficult ?
cheers from here
jigui
the LCD font size is already reduced to the minimum, for 55 characters 220 pixels are required.
But you could easily combine two 128x64 LCDs (data/control lines have to be connected in parallel, only chip select lines have to be separated)
All button and LED functions are free assignable, and there are two layers which allow you to make two button functions selectable, see lc_io_tables.inc
Thank you Master  :)
another question ... i have some difficulty with english language  :-[ (shame on me ..) so it's perhaps stupid :
i have made a Tiny Coast (few years ago) and mb the pic id inside is 0000 0000 0000 0000 (it's a pre-programmed pic i don't have a burner)
i think understand that it can be change with miostudio and that i don't have to burn the pic,  i'am right ?
bests regards,
jigui
yep. you need to upload the change id application for that:
http://ucapps.de/mios_download.html -> Troubleshooting -> change_id_v1_9e.zip
 This program allows you to change the ID header without reburning the chip --- use this program with care and read the informations given in README.txt!
hi jiugi
i use 2x 128x64 GLCDs in my MBLC and it is a really nice solution, you can have all encoders and buttons to line up decently with the tracks colums/pots
Simone
Yes good idea  :) ok so i' will buy a second LCD  ...
in this case Thorsten said that "chip select lines have to be separated" what does it mean ?
it's about CS1& CS2 on J10 of the core module ?
regards
jigui
It means, that CS1/2 of the core are connected to the left GLCD, and CS3/4 to the right GLCD
If you would use a 240x64 display, you would have to connect all 4 CS lines to a single GLCD (because in fact such a GLCD consists of four KS0108 controllers)
