TafterT Posted November 16, 2008 Posted November 16, 2008 Hi ,I have been trying to change my Sid's midi channel via sysex using this command "F0 00 00 7E 4B 00 06 70 00 10 05 00 F7" ,for midi channel 6 the problem is it doesn't change ,the sid seems to be working ok in regards to receiving midi as it can play notes form the keyboard in mios studio and i can get patches onto the bankstick ,am i using the right sysex command? ,the program i am using is Midi-ox . Thanks
TafterT Posted November 16, 2008 Author Posted November 16, 2008 Hi,Its a V2 ,it could be that i haven't set up the Midi-Ox software correctly ,i will have another go at it !Thanks
TK. Posted November 16, 2008 Posted November 16, 2008 I just have tested it - works fine.Your MBSID should respond with: F0 00 00 7E 4B 00 0F 01 F7after the SysEx string has been sentBest Regards, Thorsten.
TafterT Posted November 16, 2008 Author Posted November 16, 2008 Hi,When i send the command it seems to go into a loop SYSX: F0 00 00 7E 4B 00 0F 01 F700063A24 1 4 F0 Buffer: 9 Bytes System Exclusivethis is what it says
TK. Posted November 16, 2008 Posted November 16, 2008 Ok, so the MIDI channel has been changed correctly.You should see the new channel at the main page?Best Regards, Thorsten.
TafterT Posted November 16, 2008 Author Posted November 16, 2008 Hi,Its still on midi channel 1 as far as i can tell ,my lcd is damaged and has become unreadable ,i have another one in the post though !
TafterT Posted November 18, 2008 Author Posted November 18, 2008 Hi,Ok new lcd succesfully installed !managed to change midi channel ,was responding on channel 6 also stated it was on 6 on lcd , when i rebooted the Sid it went back to channel 1 I have searched the forum and the closest thing i could find to this was here http://www.midibox.org/forum/index.php/topic,11173.0.html but it looks like he has a v1 Sid .thanks
