Ok, i'm on the mouser site and I'm getting a bit confused.
I'm checking the encoders on this page :
http://www.mouser.com/catalog//614/660.pdf
First of, Is there a big difference in performance between 36 detents res 18 and 24 detents/24 res ?
The 36 detents are much more expensive and I wonder if the 24 detents can do the job .  The 24 detents/24 res are 1.47$ which I find pretty strange, are they crap ?
Now on the site they say to choose non detented encoders, are those ones non detented ?
Thanks,
Nat
Hey Nat
I hav'nt looked at mouser but the encoders are rated in ppr pulse per revolution.
16 ppr up to i think 32 is ok
Obviously the higher the ppr the more pulses are recieved in mios per revolution and the quicker the adjustment of a given parameter.
Detent / undetent.......mios can be configured to accept either
Only 16E does'nt use detented encoders
Ian
I'm getting quite confused.  As I understand, the Midibox16e only support non detented encoders, meaning that when you turn it, you don't feel any ticks.
I was reading some threads at the french forum and they the that the 16E supports only detented encoders....
I don't understand :((
I just visited a music store and tested some controllers with encoders and I definately want Non detented ones, they are smoother, I'd don't like that step feeling with the detented ones.
Now, where to find non detented ones that have a good resolution ?
Just an idea...
It may be possible to dissessemble and remove the ratchet on some detented encoders for non-detented operation...
Best...
Dan
Mouser has some 318-ENC160-24P from Xircom/Alpha that looks nice and are not too expensive.  They are non detented.  I just wonder if they are good, will wait to see if someone who has some comment on them.
Nat
Nat
Nat, take a look at the datasheet for these (on the mouser site).  It shows them as detented.  I don't know which is right, the catalog or the datasheet, so if anyone knows, please speak up!
:D
Smash
