cimo Posted January 11, 2009 Posted January 11, 2009 hilooking for the electro-harmonix 2880 service manual or parts list, a resostpr blown out and need replacement, URGENT!Simone
/tilted/ Posted January 12, 2009 Posted January 12, 2009 Sorry cimo, can't help with the manual, but maybe I can help with diagnosis?tell me where it hurts...The unit seems to be a cross between a looper delay and a multitrack recorder. I'd suggest there would be a lot of repetition in there, maybe you can analyse a repeated section to find what resistor you need?
cimo Posted January 12, 2009 Author Posted January 12, 2009 hii know perfectly which resistor is gone, the little bastard blasted himself against the steel inside of the frontpanel, due to a broken power supply. It s FB8 or FB9But i had an idea: if anybody had a unit and could measure or see the resistor and tell me the value that would be awesome.. maybe it s time to post at gearslut..Simone
rosch Posted January 12, 2009 Posted January 12, 2009 hi! i'm pretty sure you can watch this as a newbie's answer.here's a link to the ehx website where you can download that manual as pdf but it doesn't seem to be what you need...http://www.ehx.com/search?cx=002969883301010512651:vh8tl6tsvvi&cof=FORID:11_SEMICOLON_NB:1&ie=UTF-8&q=2880&sa.x=0&sa.y=0&sa=Searchroger
