I have built a core on vectorboard a while back.  Since I have it I don't want it to go to waste.  But the problem is the PIC is not running.  I know that it is not the pic because I can put it in my working core and it works.  What are the minimum connections for the PIC to run?  I was thinking it would be Pins 1, 11, 12, 13, 14,31 and 32.  Anyone correct me if I am wrong.
Hello Jeroddumas.
As for the pins I believe that:
1
11
12
13
14
31
32
Need hooked up like you said &
(6 to 1kohm to 5v) (to tell if bankstick is there or not)
(18 to 10k to 5v)(If AIN not used?)
(20 to 10k to 5v)(for the DIN, not & used)
(2-5, 7-10 ground) (If AIN not used)
I believe this is all that you need hooked up besides the MIDI pins 25 and 26, I am unsure if you need to hook these up yet to see if the PIC is running.
These pins are the ones that I had and along with the MIDI and it works!
Good luck
-Sephult
