Hello all,
i build the stepC of the Mbsid (90% finished) and everthing is working. (i will do the report later in an other topic).
Now i want add a button to control the sync of the Mbsid lfo, just like the lfo waveformbutton.
One button and two leds (off,asn,allnote).
How can i do that?
thanks
chriss
Hi Chriss,
unfortunately such a modification requires a lot of small changes in different files. A more comfortable solution is not possible due to timing reasons.
So: the LED status has to be saved in a temporary register.
See cs_menu_leds.inc, search for "LFO waveform" -- there are still 3 bits free in TMP5 which could be used.
Once this assignment has been made, you can access to this status register in cs_menu_io_tables.inc (take the last DOUT_ENTRY as example)
In cs_menu_io_tables.inc you also have to call a function when the "sync" button has been pressed (see CS_MENU_BUTTON_LFO_Wav as example)
search for "CS_MENU_BUTTON_LFO_Wav" in cs_menu_buttons.inc --- just copy & paste the function, rename the label to "...LFO_Sync" change the cursor position from 0x01 to 0x04
Hello Thorsten,
so half of this little mod works so far, the button does what it should do. But not the leds though.
i changed in cs_menu_leds.inc  the file from
;; TMP5[4..0]: LFO waveform
     call      CS_MENU_MS_GetSIDBase
     call      CS_MENU_Hlp_AddLFOOffset
     swapf      INDF0, W
     andlw      0x07
     call      MIOS_HLP_GetBitORMask
     IFCLR      INDF0, 0, movlw 0x00
     movwf      TMP5
to
;; TMP5[6..0]: LFO waveform
     swapf      INDF0, W
     andlw      0x07
     movwf      TMP5
is that all?
and in the cs_menu_io_tables.inc
DOUT_ENTRY      TMP5, 0,                        5,      1      ; LFO Sine LED
     DOUT_ENTRY      TMP5, 1,                        5,      0      ; LFO Triangle LED
     DOUT_ENTRY      TMP5, 2,                        4,      7      ; LFO Saw LED
     DOUT_ENTRY      TMP5, 3,                        4,      6      ; LFO Pulse LED
     DOUT_ENTRY      TMP5, 4,                        4,      5      ; LFO Random LED
   DOUT_ENTRY      TMP5, 5,                        4,      4      ; LFO Sync Asn
   DOUT_ENTRY      TMP5, 6,                        4,      3      ; LFO Sync All
thanks
chriss
BTW: Is "Lfo Random" not supported? in the menu the Lcd tells me "off"and the led  does not light.
Hi Chriss,
Random LFO is one of the new features of the upcoming V1.5
With "andlw 0x07" you've masked out the interesting bits. However, I would recomment following four lines after "movlw TMP5" of the original code:
   btfsc INDF0, LFO_MODE_SYNC
   bsf TMP5, 5
   btfsc INDF0, LFO_MODE_SYNC_ALL
   bsf TMP5, 6
(unfortunately the IFSET macro doesn't work with more than three parameters, therefore btfsc == bit test, skip if clear" has to be used without the macro)
