I hope this is in the right topic - seemed closest anyway, but I apologize if I got it wrong either way :)
Is it possible that the link to the forums in midibox.org could be updated? It's pointing to forums.midibox.org instead of midibox.org/forum. The problem is that forums.midibox.org is in a different namespace and, at least I think, that's causing SMF not to be able to read the login cookie. The end result is that the first link throws you into the forum without being logged in, which means you can't see which posts have been updated or not, etc. Simply clicking Home on the forum fixes it, but it would be ideal if the link could simply be updated, or someone put in a redirect from forums.midibox.org to midibox.org/forum.
On an aside, is there any way to donate to the cause? Technically or otherwise, but I was mostly referring to hosting costs. I can't imagine all this is hosted for free, and I know I would donate given the chance (even if it is just a marginal amount if many people did that, it might help out). Just a thought.
