masterkeyboard controller with core-module
clem!
Hi all,
after a few years in the corner of my room I want to rebirth my really very old Böhm (maybe Fatar?) 61-key keyboard add a new better looking vintage case (with wood) and offer it some masterkeyboard functionality.
OK here is the story:
In the 70th my elder brother had build up an e-piano (from the Elektor-schematics) into a Böhm organcase (really ugly!!). This e-piano never worked completly and sounded horrible.
In the 80s I needed a midi-keyboard but had no money and so I took this case with the keyboard and added Doepfer LMK2. And there was a really nice to play waterfall-like-dynamic keyboard that works fine - but had no additional controls and since I had another keyboard I didn´t need it any more.
What I want to do:
At first I want some basic controls:
modulation wheel/pedal
pitch-wheel
volume-fader/pedal
sustain-pedal/connector
buttons for prg up and down
a display that shows the program-number
at second:
first let´s look if it works
Yesterday I´ve ordered a core-module-kit from Mike and hope that this is enough for the first steps.
;-) maybe I can add some parts of a broken ADD-two perhaps the display the LED and the incrementor.
Let´s see
clem!
4713_world_png0fd406e401da2c937bd181b6c1
5791_0a21a4d7a7cc76c1d0db6558d6705930b14
Edited by clem!
hi stryd_one,
as told above I want to get some master-keyboard-control-possibilitys. Out of this reason I want to save J5 for the analog pots. I can´t find an instruction of how to connect digital switches and buttons to the core V3. But I wanted to connect an incrementor and 2 or more buttons to make prg and channel changes and maybe s.t. more.
Meanwhile I´ve tested the core - the soldering doesn´t look perfect but it seems to work :-). And the raw-case of the keyboard is ready. Perhaps I will make some pics of the keyboard and the controls at the weekend.
In the meantime I´ve put the wooden parts of the case together. Mios and midimon is up and running on the box and after some connectivity-problems the display from the add-two is working too. I´ve destroyed the contacts a little bit at unsoldering from the Dynacord which is real "german-worth-work" from the 80th.4561_kbkpl_jpg698f4453480546d10996651180
Edited by clem!
hi all,
I´ve build a little circuit with two ICs so that I can connect up to 16 switches (perhaps an old phone must die for the switches). The incrementor is still working too. I have changed the midibox64.hex to a self compiled one with unmuxed AIN and put a first pot to AIN.
At the first glance it seems to work fine ... but than I turned the pot low - and if the value runs under 16 the display dies and if I turn the pot back to the right I only see a black beam like at the startup. Midi is working correctly. Tried also the oiginal hex and reloaded Mios but that didn´t help. :-(
clem!
Sounds like you have your pot wired wrong, so that the pot causes a short when the wiper is all the way to one side. Probably you have something like
A----------B
C (wiper)
It should be:
A is 5V, B is 0V, and C to the AIN.
I think you may have done
A is 5V, C is 0V, and B to the AIN.
In that case, with the pot all the way down (wiper C next to point A) there is no resistance between 5V and 0V == you have a short == dead core.
mmh - I smell it, too.
but it wasn´t the problem. I´ve checked every soldering and found a missing wire at the lcd, as I told there were still midi-out signals without display showing anything, when I turned pot left.
This evening shot a telephone with a display at ibay for 1 EUR, hope this will work better and I can use the switches and perhaps a part of the housing. will fetch it tomorrow.
Yes the smell gets stronger - it´s the Lötkolben don´t know in english. (soldering-iron?)
Here are some pictures to document the process.
Here is one of the again working LCD.
Here another one of the place where the dead wingman wheel will take place.  ;)
Here another of the wingmanwheel. I think red buttons and knobs will do it.
4676_mbelec_jpg06e114159cddcce31f137d47d4678_kb_jpg6b6122e1ba94657c2c6f5deafdecb4680_wheels_jpg860166c1fa867e1acb6098a48
Edited by clem!
hi all,
meanwhile I´ve made a bottom for my housing out of steel 0,75 mm (pictures will follow) and can begin to place the electronics inside. Perhaps I will change the wingman-wheels to more professional ones from fatar. For the top I will choose a modular concept with min. 5 panel elements first one will be a main control panel for the midibox with LCD, some switches and 1 or 2 encoders, which will be placed in the middle, and second one will be a controller-knobs-panel with 4 pots and 4 switches, (maybe later expanded with another LCD and more pots and switches, the rest will be reserved for later adds ;)
When I thougt about controllers I got the idea that I would like to build an aftertouch-sensor. In an old manual for the lmk3 from doepfer I found that in the early days they´ve done it with piezos.
Is it possible to connect a piezo to the ain and regulate it with a L7805 to 5V?
http://www.datasheetcatalog.org/datasheets/270/9138_DS.pdf
Who has done s.t. similar?
Best regards
clem!
hi there,
at the weekensd I had a little time to push the project forward.
Now I have the metal part for the top, but it needs some drilling and milling and some black colour.
Before I can do it I need some good looking buttons and knobs and a red inverse display.
But I have the idea to connect the keys of the keybed directly to the core. I´ve studied the posts of qbas. But my keybed has no scanmatrix but 2 "Sammelschienen", "Ruhekontakt" and "Arbeitskontakt" and I thought of rearranging them, that they work like a fatar scanmatrix. I will cut it in parts of 8 notes one of these can be seen in the schematic.
Will this work? I´m not that firm in electronics can s.o. check this?
Best regards
clem!
5260_8er_matrix_giff77989f8d110162ee8a08
Edited by clem!
Thanks for the reply - not so much people interested here in Direct-Music-Application and Handiwork.
Ok - I´ve done some soldering work with another slaughterd böhm-manual.
This is just a prototyoe - quick and dirty  - shouldn´t win a beauty contest, the inverter is still missing but the contacts work here are some pics:
I will test at the weekend.
Best Regards
5280_vel_sm_1_jpg700f5c092940aa75a42d777
5282_vel_sm_2_jpgc806304b306bd8ba6767333
5284_vel_sm_3_jpg20d5dfc01fd9b1209d0ca8b
5286_vel_sm_4_jpg3d5ce5cba363a37115abb03
Edited by clem!
