I just got a nintendo ds touchscreen ( check out sparkfun, I can't post the link cause I'm on my iPhone)
I'm yet to try it out, but for $10 it might be a good x/y pad for midiboxes.
Sparkfun says you run 5V across 2 pins, then by reading the other 2 pins you get an x and y voltage.
I'll let you know how I go.
  • 3 weeks later...
From what I understand 2 of the lines are supplied with 5v and the other 2 will have a resistance one for the x, one for the y.
I havn't had time to test it yet to see what the resistance is, if it's 0-10k ( I hope) then it should just go into 2 AIN pins.
