levon Posted February 19, 2009 Report Share Posted February 19, 2009 I just got a nintendo ds touchscreen ( check out sparkfun, I can't post the link cause I'm on my iPhone)I'm yet to try it out, but for $10 it might be a good x/y pad for midiboxes.Sparkfun says you run 5V across 2 pins, then by reading the other 2 pins you get an x and y voltage.I'll let you know how I go. Quote Link to comment Share on other sites More sharing options...
ultra Posted February 19, 2009 Report Share Posted February 19, 2009 you might be able to modify the driver linked in this thread:http://www.midibox.org/forum/index.php/topic,11967.msg110413.html#msg110413 Quote Link to comment Share on other sites More sharing options...
bosone Posted March 7, 2009 Report Share Posted March 7, 2009 will this work with the AC sensorizer?i dont understand: the output signal (XY) is analog or digital? Quote Link to comment Share on other sites More sharing options...
levon Posted March 9, 2009 Author Report Share Posted March 9, 2009 From what I understand 2 of the lines are supplied with 5v and the other 2 will have a resistance one for the x, one for the y.I havn't had time to test it yet to see what the resistance is, if it's 0-10k ( I hope) then it should just go into 2 AIN pins. Quote Link to comment Share on other sites More sharing options...
bosone Posted March 9, 2009 Report Share Posted March 9, 2009 if it is so, i will buy one!please report! ;) Quote Link to comment Share on other sites More sharing options...
