levon Posted February 19, 2009 Posted February 19, 2009 I just got a nintendo ds touchscreen ( check out sparkfun, I can't post the link cause I'm on my iPhone)I'm yet to try it out, but for $10 it might be a good x/y pad for midiboxes.Sparkfun says you run 5V across 2 pins, then by reading the other 2 pins you get an x and y voltage.I'll let you know how I go.
ultra Posted February 19, 2009 Posted February 19, 2009 you might be able to modify the driver linked in this thread:http://www.midibox.org/forum/index.php/topic,11967.msg110413.html#msg110413
bosone Posted March 7, 2009 Posted March 7, 2009 will this work with the AC sensorizer?i dont understand: the output signal (XY) is analog or digital?
levon Posted March 9, 2009 Author Posted March 9, 2009 From what I understand 2 of the lines are supplied with 5v and the other 2 will have a resistance one for the x, one for the y.I havn't had time to test it yet to see what the resistance is, if it's 0-10k ( I hope) then it should just go into 2 AIN pins.
