Kyo Posted February 20, 2009 Posted February 20, 2009 I'm sorry, the read-only svn access isn't supported anymore, since it slowed down the server too much.svn access is available again - a special demon has to be started to get it running - this has to be done after each rebootI could give you ssh access to the repository if required.If this is too complicated, just download the latest stribe firmware release package, it contains the driver module as wellBest Regards, Thorsten.I get "connection refused" every time I try to connect. Is the daemon down ? I would like to try-out that SEQ V4 GNUStep implementation.Thanks.
