92 -
Everything posted by Kyo
Hiya ! Any update ?
Correct
Here is a first draft of what I have in mind.
I was thinking of 12(V)*2(taps)*2(A) = 50 VA (as of the original NorthenLightFX proposal) in order to get 2(taps)*(2*+5VDC, 2*+9VDC) from the secondaries. I am not planning on using every output at once. Just to have mb6582 on one tap and 2*SEQ v4 on the other. The idea is to design the psu to be reusable. Am I on the right track or did I miss it completly ? :)
Thanks four your reply, I had a double winding (see pic (no those are not butts ...)) transformer in mind when writing the previous post. I plan to use a R-core transformer. So it would have 2 bridge rectifiers.
Hi, I am also looking for a replacement for the C64 PSU. I have been enjoying my brand new mb6582 for a month and then the PSU died in a white smoke final breath... I would not normally look into building my own as I do not know anything about PSU design but I can't find a linear +9/+5V that would suit. I am now considering building NorthenLightFX PSU for a replacement. I am wondering if I can jump to building straightaway or if I should get math & electrical knowledge before I start. Any thought ? Also is it possible to customize the design just by deleting and copying/pasting power lines behind the bridge rectifier ? In order to get 2 x 9V and 2 x 5V from the secondaries. That would make a single PSU with two blocks of 2x5V, 2x9V outputs, each block supplying 2A. This seems too easy, so I guess the answer is no. :)
No sowwy. I reuploaded boot loader from scratch then mios & app and still no sound and corrupted behaviors.
I do not know if this could be related but I found myself in the same situation this week end. I fried a PIC by accidentally touching pin 28 (SID socket) while bridging pin 8 & 27 to perfrom the test tone. Pin 28 is 9/12V. As a result I got no more sound on one channel and half volume on the other one. Also I can still upload mios and apps to this PIC but it shows strange behaviors (mios locked in rebooting loop, messed up characters and the like...).
Hello. In order to download/synchronize/upload (called checkout/update/commit) the source code you need a subversion client. Either a command line tool (from tigris I guess) or a GUI tool (Cannot point one to you as I am not a Mac user). Everybody has read access. To be able to commit you need write access. All you have to do is to direct your client to the svn URL and checkout the repository. mios svn URLs are: svn://svnmios.midibox.org/mios svn://svnmios.midibox.org/mios32 Hope it helps. Edit: I think this can help you http://theappleblog.com/2008/04/28/using-subversion-with-xcode-30/
40x2 Green-on-Black Optrex Displays - ORDERING INSTRUCTIONS
Kyo replied to fussylizard's topic in Bulk Orders
LCDs arrived today. No taxes makes me really happy. Thanks fussy. -
Big hurray to all for the newborns.
TheRainbow - Midibox and RGB Led Keyboard
Kyo replied to julienvoirin's topic in MIDIbox User Projects
Hi julien, any progress on your project ? -
Yes and yes. Seq v4 manual has been updated recently: http://www.ucapps.de/midibox_seq_manual_hw.html
I think best thing to do here is again to wait. Wilba and Doug are still working on a desktop solution. Which should be rack-able thanks to additional rack ears. Final panel design may change once they are done. I'm certain something great will come out of this.
fussylizard 2 strophlex 4 nsunier ~10 rosch 4 ssp 2 (maybe 4) gtxdude 2 matoz 4 lucem 6 enth 3 flemming 1 kyo 4 wilba 6 dstamand 1 olga42 5 latigid on 2 kokiPsiho 2 ---------------------- ~58 Changed from 2 to 4
Got mine as well. Really nice piece of work. Kthxbye.
Knobs arrived today. Thanks goblinz.
I'm in. fussylizard 2 (?) strophlex 3 nsunier ~10 rosch 3 ssp 2 (maybe 4) gtxdude 2 matoz 4 lucem 6 enth 3 flemming 1 kyo 2 ---------------------- ~38
I think you completly ruined your credibility...
It's allright goblinz. We all have personnal real life ;). Hope things are allright for you.
Can't you use your pads with AINs instead of DINs ? Those pads are designed to provide velocity why would you turn them into simple push buttons ?
Surgery table all set up. You can bring 'em in.
Couldn't we use a metal panel with acryl enclosure ?
