Modularman Posted February 22, 2009 Report Posted February 22, 2009 Does MBFM work ok with 18F4685 or am I better sticking with original 18F452?I intend building with full control surface and 8 bank sticks, guess there's no advantage in using 24LC512 rather than 24LC256?Thx in advance,Allan
TK. Posted February 22, 2009 Report Posted February 22, 2009 Yes, it should also work on a PIC18F4685, although I never tried it.A 24LC512 doesn't give you any advantage, because only the lower 32k range is used.Best Regards, Thorsten.
Modularman Posted February 22, 2009 Author Report Posted February 22, 2009 Many thanks for the fast reply Thorsten, I'll go with PIC18F4685 and get the parts ordered up now.Another MBFM will be added to the ranks soon :)Cheers,Allan
Imp Posted April 6, 2009 Report Posted April 6, 2009 you probably need to treat the pic as if it were a pic18f452, as i've described here: http://www.midibox.org/forum/index.php/topic,11972.0.html
