goyousalukis Posted July 12, 2003 Posted July 12, 2003 Hello, I have built a mb64seq with the old PIC. I have run the AIN test program, and it works great, but I am trying to get the dout test program to work. I would like to know whether all the LED's are supposed to flash on boot up or not. On mine only two flash quickly. Then when the program starts cycling, halfway through the cycle, those two LEDs light and stay lit. No other LEDs light. Also, does it matter that I am only using 16 LEDs? The test program cycles through 32. Is this a problem?Thanks for any ideas...Justin
pay_c Posted July 12, 2003 Posted July 12, 2003 I would just try to burn the whole programm. I always do that.Just burn the MB64SEQ Proggy and look if everything is fine. If it is, forget the test programms.If its not, *THEN* you can go back to those.
