abcmann Posted March 20, 2009 Posted March 20, 2009 Hi, I'd like to start my first own project. I just have some basic ideas of it, so I decided to post it in design concepts firstly. I've ordered the last missing parts already. The casing isnt built yet, because I first need to know how my box should work when its ready.Like you perhaps already read, it should get into a filter fx.What should this baby do ?- 4 independent ins and outs Four channels, ..... so 1 aout module, 2 ssm pcbs and 4 ssm's.- Envelope Detector circuit there are some circuits on the net. It's output should be read with an AIN and should be assigable to every parameter- 3 envelopes with DADSR per channel freely assignable to the env.detector / frequency / resonance triggered by env.detector value or by midi- some lfo's freely assignable to all parameters of the envelopes and filters based on realtime or midiclock/BPM- routing the filter in series or parallel I think to use MAX4550. I have several here. Its a dual 4in/2out crosspoint switch.- feedback loop some shapes if ideas, but nothing more yetany suggestions from you ?bye
stryd_one Posted March 20, 2009 Posted March 20, 2009 Why analog envelopes into AIN? You can just do digital envelopes ;)
Futureman Posted March 21, 2009 Posted March 21, 2009 Why analog envelopes into AIN? You can just do digital envelopes ;)does he mean an envelope follower of external signals.. sort of like a mutron envelope filter?RegardsMike
abcmann Posted March 21, 2009 Author Posted March 21, 2009 Yepp, thats what I meant. :DThe envelope follower can also act as a "sidechain", when you use the measured volume to set a parameter of another channel.For example volume of input d changes filter of channel a ...................
