I saw you're using seperate PSUs. This behavior indicates a coupling between the two supplies, so it must lie elsewhere. I'd say check for shorts or any other possible source of coupling (defective cap, blown IC)
I think MTE was joking about the multiple power supplies ...
... this was not a joke. I think I first saw that on Doc's LC. Actually not multible powersupplies, but multible regulators.
Just redesign the MF board, so you have a regulator (incl. Trimmers, resistors...) for every single fader.
Greets, Roger
PS: But I still think that this is not really the problem of your Box' behaviour.
Well, sorry I misinterpreted your post ...
So the intent of putting one regulator / fader would be to have 1.5A current capacity/fader ?
According to the datasheet 1.5A could nearly supply 2 faders @800mA each, so 1 LM317 per fader pair should suffice
You'd need quite a hefty transformer though, that could supply 7 amps ...
One thing that seems strange is that cinchet says 'my lcd gets darker' and '5v rises to 5.4v', I would believe the rise of the 5V line should make the backlight lighter, not darker
  • 1 year later...
