cinhcet Posted May 25, 2009 Author Report Posted May 25, 2009 mhh, but why is the 5V affected?(LCDs get darker and somtimes the wohle core reboot)
Lorcan Posted May 25, 2009 Report Posted May 25, 2009 I saw you're using seperate PSUs. This behavior indicates a coupling between the two supplies, so it must lie elsewhere. I'd say check for shorts or any other possible source of coupling (defective cap, blown IC)
Screaming_Rabbit Posted May 26, 2009 Report Posted May 26, 2009 I think MTE was joking about the multiple power supplies ...... this was not a joke. I think I first saw that on Doc's LC. Actually not multible powersupplies, but multible regulators.Just redesign the MF board, so you have a regulator (incl. Trimmers, resistors...) for every single fader.Greets, RogerPS: But I still think that this is not really the problem of your Box' behaviour.
Lorcan Posted May 26, 2009 Report Posted May 26, 2009 Well, sorry I misinterpreted your post ...So the intent of putting one regulator / fader would be to have 1.5A current capacity/fader ?According to the datasheet 1.5A could nearly supply 2 faders @800mA each, so 1 LM317 per fader pair should sufficeYou'd need quite a hefty transformer though, that could supply 7 amps ...One thing that seems strange is that cinchet says 'my lcd gets darker' and '5v rises to 5.4v', I would believe the rise of the 5V line should make the backlight lighter, not darker
bwanatikh Posted September 8, 2010 Report Posted September 8, 2010 (edited) how did you in-cooperate the LED bar graph into the system? do you have the circuit for that? Edited September 8, 2010 by bwanatikh
Screaming_Rabbit Posted September 8, 2010 Report Posted September 8, 2010 how did you in-cooperate the LED bar graph into the system? do you have the circuit for that? http://ucapps.de/midibox_lc/midibox_lc_ledrings_meters.pdf Greets, Roger
bwanatikh Posted September 9, 2010 Report Posted September 9, 2010 (edited) http://ucapps.de/midibox_lc/midibox_lc_ledrings_meters.pdf Greets, Roger Wow! Thats great.Thanks a lot.i also got more info from this website.might help others...maybe! http://www.mbeckler.org/microcontrollers/led_bargraph/ Edited September 9, 2010 by bwanatikh
