GCoda Posted April 18, 2009 Report Posted April 18, 2009 hi, i don`t know ASM so i decided use Ci get mios_base_v1_0b, get some exemples and compile this:main.c PIC18f452-i/pi am using inly core and dout, nothing else, maybe LCD neededor somthing else ? #include <cmios.h> #include <pic18fregs.h> #include <cmios.h> #include <pic18fregs.h> #include "main.h" app_flags_t app_flags; unsigned char last_ain_pin; unsigned char last_din_pin; unsigned char last_dout_pin; void Init(void) __wparam { // set shift register update frequency MIOS_SRIO_UpdateFrqSet(1); // ms // Up to 4 DOUTX4 modules (=16 shift registers = 128 digital outputs) can be connected // set the maximum number here - it doesn't really hurt! MIOS_SRIO_NumberSet(4); } void Tick(void) __wparam { } void Timer(void) __wparam { } void DISPLAY_Init(void) __wparam { } void DISPLAY_Tick(void) __wparam { } void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { if( evnt0 == 0x80 || evnt0 == 0x90 ) { if( evnt0 == 0x80 || evnt2 == 0x00 ) { // Note Off MIOS_DOUT_PinSet(evnt1, 0); } else { // Note On MIOS_DOUT_PinSet(evnt1, 1); } } } void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { } void MPROC_NotifyTimeout(void) __wparam { } void MPROC_NotifyReceivedByte(unsigned char byte) __wparam { } void SR_Service_Prepare(void) __wparam { } void SR_Service_Finish(void) __wparam { } void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam { } void ENC_NotifyChange(unsigned char encoder, char incrementer) __wparam { } void AIN_NotifyChange(unsigned char pin, unsigned int pin_value) __wparam { } and nothing working, only one led are lights 7th (doutx4)where im wrong?help please, sorry for bad english
nILS Posted April 18, 2009 Report Posted April 18, 2009 The LCD is not needed.Does the test app (http://www.ucapps.de/mios/ain64_din128_dout128_v2b.zip) work, so you know your DOUT is working correctly?void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam{ if( evnt0 == 0x80 || evnt0 == 0x90 ) { if( evnt0 == 0x80 || evnt2 == 0x00 ) { // Note Off MIOS_DOUT_PinSet(evnt1, 0); } else { // Note On MIOS_DOUT_PinSet(evnt1, 1); } }[/code] That part looks kinda fishy. Try to always use () Try: [code]void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam{ if( (evnt0 == 0x80) || (evnt0 == 0x90) ) { // note on or note off if( (evnt0 == 0x80) || (evnt2 == 0x00) ) { // note off or volume == 0 MIOS_DOUT_PinSet(evnt1, 0); } else { // Note On MIOS_DOUT_PinSet(evnt1, 1); } }The code itself looks correct except for that tiny thing, so I'd assume the problem is in hardware or you don't send the right note events ;)
GCoda Posted April 19, 2009 Author Report Posted April 19, 2009 Does the test app (http://www.ucapps.de/mios/ain64_din128_dout128_v2b.zip) work, so you know your DOUT is working correctly?what will that app do ? dout will reacts incommming midi events?
GCoda Posted April 19, 2009 Author Report Posted April 19, 2009 midi input center pin maybe need to be ground ?i am using only to of 5... thatmay bee problem ?
nILS Posted April 19, 2009 Report Posted April 19, 2009 Read the readme.txt or check the main.c for inforamtion on what the apps do and how to control it."Middle" MIDI Input pin does not need to be grounded and more precisely shouldn't be grounded. Using only 2 pins is correct.Again: Do you _KNOW_ (and if so how?) that your core is fully working? Did you upload MIOS or an application? If so, how and were there any problems? Give us some information - that makes it a lot easier to help you...
GCoda Posted April 19, 2009 Author Report Posted April 19, 2009 compiled, and uploaded with icprogtryed int i,j; for(i=127, j=0 ; i!=j ; i--, j++) { MIOS_DOUT_PinSet(i, 1); //may be this not working MIOS_DOUT_PinSet1(j); //or this not working }and this not working too... think thap i wrong in hardware... iam not very pro in this stuff.... biut buy a ready pcb in my coutry is a problem....checking and checking hardware....
philetaylor Posted April 19, 2009 Report Posted April 19, 2009 Do you mean you compiled and then uploaded your own program with ICPROG and NOT MIOS Studio?Do you actually have MIOS on the PIC? MIOS must be uploaded seperately. Once MIOS is on the PIC then you can use MIOS Studio and MIDI to upload your program, this will ensure that MIOS doesn't get overwritten by your program and is much easier.You can tell if MIOS (or Bootloader) is operational by connecting a MIDI port to your PC and seeing if you receive a Sysex 'upload request' from the CORE.Cheersphil
GCoda Posted April 19, 2009 Author Report Posted April 19, 2009 .... o_Oi downloaded mios_base_v1_0b goto apps\templates modify one and compile...that is no mios inside 6kb hex file ?i should upload compiled mios_v1_9f_src (mios_p18f452.hex) or somesing like that?and after it upload that i compiled from mios_base_v1_0b?can i do this with icprog without mios studio?edit:i need to upload mios_p18f452.hex than i need to use mios studio and try to upload my app...this is best and right way...?i have no pc with midiIO at home... i ll buy one... and before this i ll try whit icprog
philetaylor Posted April 19, 2009 Report Posted April 19, 2009 Ahhhh That explains why it isn't working, you don't have MIOS on the PIC.Yes you are quite right, you need to have MIOS (mios_p18f452.hex) on the PIC before you can load your app. I have never used icprog but you should be able to use it to load MIOS. I would then recommend using MIOS Studio to then load your app. You may be able to use icprog to load your app as well but you need to make sure it doesn't overwrite MIOS.CheersPhil
GCoda Posted April 20, 2009 Author Report Posted April 20, 2009 for sure...i need upload just mios than in mios studio do other thingsbootloader don't needed ??or i need upload bootloader and than in studio upload mios and than in studio upload appor is doesn't matter,as i read in "MIOS Bootstrap Loader for Newbies"The communication protocol of both loaders is identical, accordingly the same tools can be usedthanks for answering my stupid question......its all too difficult for me, i am badly understand English and electronic stuff...
stryd_one Posted April 20, 2009 Report Posted April 20, 2009 Gday GCoda,or i need upload bootloader and than in studio upload mios and than in studio upload appThat's right, you should install the bootloader by using your burner. Once that is done, you can install MIOS using MIDI, and then you can install your application using MIDI.Grab this zip fileBootloader is in /mios_update_v1_9f/pic18f452/burner/Burn that with your MBHP-Burner or JDM module.After that, you can use MIOS Studio to upload the hex files, and you should not need to use the burner any more.Can I ask what is your native language? Maybe we can find another midiboxer who can help in your native tongue... hopefully that would be easier for you.. The wiki can be confusing even if you prefer english ;)
GCoda Posted April 20, 2009 Author Report Posted April 20, 2009 Can I ask what is your native language? Maybe we can find another midiboxer who can help in your native tongue... hopefully that would be easier for you.. The wiki can be confusing even if you prefer english russian, but thanks, i now understand process and this time i do everything right i hope, only waiting for "midi to usb" for mios studio, i am using midi output from midi keyboard, and its not useful for mios studio i think...
stryd_one Posted April 20, 2009 Report Posted April 20, 2009 Cool :)Yeh sometimes the keyboard MIDI does not handle sysex well. Be sure to avoid any devices on our wiki 'blacklist' when you buy a new one!
