anakin Posted April 28, 2009 Posted April 28, 2009 HiFirst of all excuse me there's the possibility that this is a question just submitted... I try to find in the forum but without results. :)I'm using two midiboxes connected together with the classic tx and rx ports in this way:first midibox with standard Midibox64 , the midiout of it ( port TX 25 ) connected with the midi in port ( port RX 26 ) of second pic, it work on channel 1Second midibox running the scan matrix application of TK ( fast version) in an old keyboard ( midi merge function enable in the code) ,work on channel 1.I'm suffer this kind of problem:Few times it doesn't put out the Note_off message and the results is that note always stay ON and I need to re-push the key for do the Note_off.I notice that it happens when I move some pots in the first midibox, or when I'm playin' hard ( e.g. slides) so this is my question.Is it possible that the problem is caused by a kind of "data overflow" from the input of the second pic?What's about the performance of the midi merge feature? Is there any kind of filter on it?I don't think Midibox link will help in my case because I think this isn't a loop problem: what do you think about?And what's about the sharing of the same channel: is this a problem?Thank you very much for your helpAnakin
nebula Posted April 29, 2009 Posted April 29, 2009 I think you should first try disabling merge on the keyboard PIC, and then see if you can make it act up.
anakin Posted April 29, 2009 Author Posted April 29, 2009 Hi and thank you for your replyYes, I just did this and also phisical disconnect it and it change and work good.The problem seems to be the merge... that's why my question...bye
TK. Posted April 29, 2009 Posted April 29, 2009 Hi,there shouldn't be a performance problem, especially not with sm_fast or sm_slow, as these routines are executed much faster than a new MIDI event could arrive.How does it work if the first core is removed from the chain (keyboard directly connected to MIDI In of second core which executes sm_fast)?If you still notice failures, try a dummy application w/o any app code but Merger enabled.If you still notice failures after such a change, it's a hardware issue (hints to such issues later if required)Best Regards, Thorsten.
anakin Posted May 5, 2009 Author Posted May 5, 2009 Hi Tk and thank you for your reply!If I remove the first core , I don't have the problem.If I upload a dummy app on second core with merger enable all work good ( I upload the slow version of SM) So I think maybe is a hardware issue, maybe with the matrix I'm using, I have to do some tests on it, surely I can open a new treat if is a hardware compatibility problem, but it is very strange as if remove the first core the apps seems to work good!ByeAnakinp.s. I have some question about SM_fast but I post in a separate treat.
TK. Posted May 5, 2009 Posted May 5, 2009 Link to the new threadhttp://www.midibox.org/forum/index.php/topic,13485.0.html
