tongenerator Posted May 25, 2009 Report Posted May 25, 2009 Hello,i want to ask what diffrence between the versions of the *.asm files from TK and for example Wilba or cd_cd are.wich one schould i use, or wich one is the better one :Pthanks
TK. Posted May 25, 2009 Report Posted May 25, 2009 Hi,I guess that you mean the MIDIbox SEQ V3 setup files.setup_mbseq_v3 will work fine for you, the remaining files are customisations for myself, Wilba, CD and (new, will be part of the next release package) MK. They are using different LED/Button assignments, and as a personal service from my side I provide precompiled binaries for them so that they don't need to build a new .hex file by themself on new releases.If you really want to find out the differences (I don't see a need), you could run a "diff" between two .asm files, or just compare the settings line by line.Best Regards, Thorsten.
tongenerator Posted May 27, 2009 Author Report Posted May 27, 2009 hello,i just had a closer look at the *asm files and figured what they are about and understud how they work.i figured that i have to change the encoder mode for example...thanks a lot for ur replyedit:actually i found something else i want to ask...why is not possible to use a bankstick mode wich would allow to use the hole capacity and not just the 32 / 64 K,because the 24LC512 Memory i got from mouser has 512 kbit.
