tongenerator Posted May 27, 2009 Report Posted May 27, 2009 hello,what the heck :oafter i have installed the latest seqeunzer version, the datawheel is without function.when u turn it, something flikers but it is not realy changing the value, also the selectionmarker always jumpes to position 9 but it is not actually effekting anything....i just put the seqeunzer in to my rack yesterday, working all day correct without any error...so i now allready have opened it up and checked the encoder... the encoder is ok...is it possible to get back the old version, can i download the older versions somewhere, please.
TK. Posted May 27, 2009 Report Posted May 27, 2009 This cannot be related to the firmware version (it already has been tested by some people), therefore uploading an older release won't help anyhow.How did you upload the application?Did you use a different MIDI Interface this time?Did MIOS Studio report any errors during code upload?Which upload mode are you using? (hopefully "Smart mode")How did you test that the encoder is working?If there wasn't an issue during code upload, it could help to use MIDIO128 for troubleshooting the encoders and buttons.It would also be interesting to know some more details about your MBSEQ construction.E.g., flickering LEDs or non-functional buttons/encoders are a common problem if cables to the DIN/DOUT registers are too long. Also a short between SCLK and RCLK can cause this, etc... (more once you explained the details)Best Regards, Thorsten.
tongenerator Posted May 27, 2009 Author Report Posted May 27, 2009 well 5 minutes before i did the update, it workedhow ever...i uploaded it with mios studio in smart mode.this time i did not use my motu midi interface, i used the midi port of the focusrite saffire proi changed the encoder...i tried the enco at pattern thing 1, there it works...
TK. Posted May 27, 2009 Report Posted May 27, 2009 And you uploaded setup_mbseq_v3.hex, and not any other .hex file which could have a different button/LED assignment?Best Regards, Thorsten.
tongenerator Posted May 27, 2009 Author Report Posted May 27, 2009 what the fucking hell is that?i found the error...i just disconected the MIDIcable and it is back alive *puuuuuh :P
TK. Posted May 27, 2009 Report Posted May 27, 2009 I guess that you've uploaded the wrong .hex file.Please try setup_mbseq_v3.hex first, just upload the file again if you are unsure! Report the results!If it won't work I will search for an older release package on my harddisk, but I'm very sure that it won't help!Best Regards, Thorsten.
tongenerator Posted May 27, 2009 Author Report Posted May 27, 2009 sry about that... i could kick myselfof course there was a short..the short was at the dout, so everytime i connect the midicable the datawheel did not work and alsothe position marker jumped sporadisch to position 9...oh dear, i need a beer
