On the hunt for some 60mm faders
unrise_lyrical
So as per the other thread in here, I am tracking down some new 60mm faders. I had a look on Farnell (seems to be the easiest electronics site to navigate!) and came up with a HELL of alot of results.
I found 5 different 60mm 10k ohm panasonic faders...all similar price...but I have no idea what their real differences are? Also, I can't see if it is mentioned whether they are linear or log? im sure it is...but not in language I can understand (ie. I don't speak smart electronics talk).
The one thing I did notice between them all is they obviously have different power ratings. Is there any specific desired power rating for midibox64s? or just the less the better?
here they are:
http://sg.farnell.com/panasonic/ewaq10c15a14/potentiometer-slide-10k/dp/8796157
http://sg.farnell.com/panasonic/ewaq30c15d14/potentiometer-slide-10k/dp/8796190
http://sg.farnell.com/panasonic/ewaq12c15b14/potentiometer-slide-10k/dp/8796173
http://sg.farnell.com/panasonic/ewaq10c15d14/potentiometer-slide-10k/dp/8796165
http://sg.farnell.com/panasonic/ewaq30c15a14/potentiometer-slide-10k/dp/8796181
also found these ones:
http://sg.farnell.com/bourns/pta6043-2015dp-a103/potentiometer-slide-10k-60mm/dp/1688417
http://sg.farnell.com/bourns/pta6044-2015dp-a103/potentiometer-slide-10k-60mm/dp/1688419
http://sg.farnell.com/bourns/ptb6043-2010bp-b103/potentiometer-slide-10k-60mm/dp/1688410
any advice greatly appreciated :)
Open a datasheet. In the middle of the 1st page you can find the "Explanation of Part Numbers"
  • Digits 1-3: ProductCode = fix (it's this type of fader / housing /physical built)
  • Digits 4-6: Specification - Q = 60mm type, 1 = single taper (see 2nd page - drawings)
  • Digits 7-9: LeverTrims & Dimensions - I think there is only one type available (see drawing)
  • Digits 10-12: Taper & Resistance - I think "B" is linear
So you probably want: EWAQ12C15B14
Greets, Roger
