joewhat Posted June 18, 2009 Report Share Posted June 18, 2009 hi, at the moment i one have two bankstiks 24LC512. and belive it or not i have a hard time understanding this wirering ? :0)if i only have two. do i wire them like this?then flemming told me something about dedicating one bankstik to some ensemble code? - where can i read about this, read more about the bankstiks?im a little lost and confused.. hah.ok but if anyone is able to point directions or explain i would much appreciate it.thanks alot, - joe Quote Link to comment Share on other sites More sharing options...
Wilba Posted June 18, 2009 Report Share Posted June 18, 2009 When you put multiple 24LC512 (or 24LC256) on the same "chain", pins 4-8 will be the same on both (like you have in this picture)... but E0/E1/E2 must be different, they give that IC it's "ID".Here's a clearer schematic:http://www.ucapps.de/mbhp/mbhp_multi_bankstick.pdfIt's simplified a bit... you would connect up the 5V and ground pins also... this means you can join many pins of one IC together and then just connect each IC to a common wire.You can remove any of the ICs in this schematic.... ie. you can have just two, one with ID=0 and one with ID=7 (for MB-SID this is good, ID=7 is used for the "ensemble" storage, ID=0 to ID=6 is for patches). Quote Link to comment Share on other sites More sharing options...
joewhat Posted June 18, 2009 Author Report Share Posted June 18, 2009 thank you wilba, this answer make it much clearer to me. i dont know how it works. but your explanation and the link to the pdf should be added to the bankstik page http://www.ucapps.de/mbhp_bankstick.html for newbies to understand better? the schematics on that page is alittle blury and tiny.thanks again. Quote Link to comment Share on other sites More sharing options...
joewhat Posted June 18, 2009 Author Report Share Posted June 18, 2009 or at least the link to the pdf. i understand the bankstick page better after your explanation but anyhow.. :0)what is this "ensemble" on the ID7? Quote Link to comment Share on other sites More sharing options...
Wilba Posted June 18, 2009 Report Share Posted June 18, 2009 Read the SID V2 User Manual about Ensembles. Quote Link to comment Share on other sites More sharing options...
joewhat Posted June 18, 2009 Author Report Share Posted June 18, 2009 ok, i will do that. thanks again. enjoy! Quote Link to comment Share on other sites More sharing options...
TK. Posted June 18, 2009 Report Share Posted June 18, 2009 thank you wilba, this answer make it much clearer to me. i dont know how it works. but your explanation and the link to the pdf should be added to the bankstik page http://www.ucapps.de/mbhp_bankstick.html for newbies to understand better? the schematics on that page is alittle blury and tiny.The schematic was already on the BankStick page as directly visible .gif file...However, I added a link to the .pdf and Wilba's explanation (slightly changed... Wilba: if you want to change the wording, just modify the file in the repository)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
joewhat Posted June 18, 2009 Author Report Share Posted June 18, 2009 good things ! - you may have heard it before but thank you and everyone for a fantastic resource. !-joe Quote Link to comment Share on other sites More sharing options...
