mikee Posted August 29, 2009 Posted August 29, 2009 hi allIm using BrennerNG44 to burn pic16f48a.Using Brenner, I get these results:-PIC16F84 in database: Vpp : 13V (12 .. 14V)CP-Blocksize : 0800Panelgröße : 0000HEX-file-name : picF84a_test.HEX-- HEX-file loaded-- 1 k FLASH needed-- 0 Byte EEPROM needed-- HEX-file contains Config-dataChip erasedStart to program Flash##-->7 errors in PROGRAM ************* noteStart to program ID-- no ID to burn-- ID o.k.Start write Configuration##-->1 errors in Config ************* note-- finishedconfig used: __CONFIG _CP_OFF & _XT_OSC & _PWRTE_ON & _WDT_OFFinclude used: "P16F84A.INC"** Ref notes:Does anyone know why Brenner detects program errors and config error when MPLAB asm says all is fine?Cheers everyone
analogue_mo Posted September 27, 2009 Posted September 27, 2009 Hello,I was having the same problem trying to program a 16f84a.....I was getting about 22 errors in program and one error in config....fortunately, I already knew that the code wasn't the problem, cause I've used it before and successfuly burned the pic...It turned out to be a hardware problem....I had a faulty transistor(bc337) that was not shutting Vpp off, so, no matter what code I would use, I would allways get the same errors!here is a link to the thread that described this symptomshttp://www.midibox.org/forum/index.php/topic,14111.0.htmlafter replacing the transistor everything went perfectly!So my advice is:-Make sure that you're passing all hardware tests;-In order to help you debug your burner module follow this thread:http://www.midibox.org/forum/index.php/topic,14114.0.htmlGood luck!
mikee Posted October 6, 2009 Author Posted October 6, 2009 thanks for the reply analogue_mostupid as it might sound, i had not provided power and the leds seemed to say all was well, but thanks anyway mate.
