Hi there!
Does anyone can give a C code example on how to use the "free to use" pins like J10 SO and RC?
I'm using X-code and I would like to use these pins to do a PWM signal to control a servo. For a servo it's not real PWM signal but rather a high state during between 1 millisecond (0%) and 2 milliseconds (100%). As the DIN registers are refreshed only once per millisecond it's not precise enough for me. I hope that by using a timer and these pins I should be precise enough without having a code too heavy.
Thanks in advance!
Baptistou
For J10:SO you would do:
PORTCbits.RC5 = 0;
or
PORTCbits.RC5 = 1;
J10:RC is PORTCbits.RC4.
Simple enough, eh?
if (PORTCbits.RC5) {
  // pin is high do something
} else {
  // pin is low do something else
Remember to set the pin directions before using them as in/outputs.
And how do you set the pin direction?
Thank you for your help, these are easy syntax but hard to find when you are a newby like me!
It looks like I only have to put something like
TRISCbits.TRISC5 = 0 or 1
I'll try that as soon as I have the time, thanks for the help!
