I am about to start building a new Midibox SID V2. But before I start I need to clear some points, and specifically related to the power supply of the Midibox SID.
I have bought the kits from SmashTV and the PCBs are : Core is CORE_R4D, and SID is R3A.
All the questions are related to the document : mbhp_8xsid_c64_psu_optimized.pdf.
- You specify for the power main circuit to use a B40C800. Is it equivalent to a W08G ?
- You show in the schema to remove the regulators on the core module (7805), is it the only thing to remove ? I mean nothing else is to remove for the supply part on each core module ? As I am using the kits from SmashTV there is a regulator and a bridge rectifier on each core module, so do I need to connect them ? If not what connections do I have to make ?
- You show also a connection between the core modules on J11 connector where VS and MI from the master core module goes in each slave module also on VS and MI. Is it correct ? I mean shouldn't it be VS and MO from the master core that goes in each slave on VS and MI ?
- Now for the SID modules power supply. You show to use a 7809 regulator on the main supply circuit. Does this mean that we also have to remove it from each SID module as for the core modules ? If so, do I have to make a bridge between IN and OUT+ as for the core modules ? And same question as for the core module, for the bridge regulator, do I need to connect it and if not what connection do I have to make ?
- Again for the SID parts, you connect each Vd pin of the SID modules to the 14VDC pin of the power circuit. But where do I connect the Vs pin of the SID modules ?
Thank you very much for your help.
Best regards from France  :D
Germain
- W08G will work.
- You will not have to stuff the rectifiers and the 7805 on the cores (a jumper wire between pins 1 and 3 of the vreg are a nice idea, as to have the 2200u cap connected) - oh lookey you now have some rectifiers left over that you can use for the optimized PSU ;)
- MI/MO, nope that's correct, all MIDI Ins are connected in parallel
- 7809: You leave those in. Also you'd want to leave the rectifier in cause it doesn't hurt and is a nice little insurance policy ;)
- Vs connections: Look at the .pdf - on the SID modules it's J2:Vs (bottom left pin)
Thank you so much for your fast answer !  :D
- W08G will work. --> OK, perfect.
- You will not have to stuff the rectifiers and the 7805 on the cores (a jumper wire between pins 1 and 3 of the vreg are a nice idea, as to have the 2200u cap connected) - oh lookey you now have some rectifiers left over that you can use for the optimized PSU --> Great ! That was exactly my idea  :)
- MI/MO, nope that's correct, all MIDI Ins are connected in parallel --> OK
- 7809: You leave those in. Also you'd want to leave the rectifier in cause it doesn't hurt and is a nice little insurance policy  --> OK
- Vs connections: Look at the .pdf - on the SID modules it's J2:Vs (bottom left pin) --> Humm, I am afraid I don't understand. Does this mean that Vs of connector J1 of SID module is wired to the Vs of connector J2 ? Does this means that Vs of connector J1 is not to be connected at all ?
Thank you so much !
Best regards
Germain
I have one last question regarding your answer :
For Vs connection on SID modules. Does this mean that Vs of connector J1 of SID module is wired to the Vs of connector J2 ? Does this means that Vs of connector J1 is not to be connected at all ?
Thank you and best regards  :D
Germain
Correct. Simple answer to all your questions:
Everyhing that needs to be wired is in the pdf. If it's not in there, don't wire it.
