bosone Posted October 8, 2002 Posted October 8, 2002 is there a way to send a sysex to the midibox plus to enable/disable the snap mode, parallax mode, etc??it not, will you implement it for new firmware release, thorsten? (PLEEEASE!! :))
TK. Posted October 10, 2002 Posted October 10, 2002 Hi Bosone,no sorry, this isn't possible, since the MIDIbox Plus is designed for 4k PICs, I had to reduce it to the most important and requested features. If I would integrate a sysex string for switching the pot mode, I would have to delete another function which would make other peoples unhappy :-/However, you should be able to select the modes "blind" without andisplay, the necessary sequences are (after Power-On):Pot menu: Exec-Right-Right-Exec(see the MIDIbox Plus schematic for the appr. pins)Thereafter you can select the modes with the left/right buttons: Normal/Snap/Relative/ParallaxBest Regards, Thorsten.
