bosone Posted August 1, 2003 Report Posted August 1, 2003 i have just burned SID latest version on pic16f977.everything works fine (even with jsynth), but when i mount the bankstick the following things happens:- i'm not able to play anything- the SID outputs a short impulse note which pitch is constantly rising- even if i upload the preset bank with jsynth nothing happenswhat can be the problem? i checked the connections a lot of times!
TK. Posted August 1, 2003 Report Posted August 1, 2003 Hi Matteo,so, you hear a short tune when you connect the BankStick - this means that the EEPROM has been regognized.even if i upload the preset bank with jsynth nothing happens...what should happen? Did you select the Patches via Program Change? Note that Patch #1 is the internal patch stored in EEPROM, patch #2-128 are the external patches stored in BankStick.Best Regards, Thorsten.
bosone Posted August 2, 2003 Author Report Posted August 2, 2003 i hear only "bip, bip, bip, bip...." with the tone of "bif" always incrasing (say it plays a C, D ,E ,F, G,A ,B, etc)it is normal??? and besides this, i can't play and yes, i used the program changes after uploading all the presets with jsynth...
TK. Posted August 3, 2003 Report Posted August 3, 2003 Alright, this explains everything :)Your BankStick has not been formatted yet, the firmware tries to do this - a "beep" can be heared after every formatted patch, so you have to wait for 128 "beeps" until the BankStick is ready for use. It takes about 3 minutes.During the formatting procedure all other SID functions are disabled. When you interrupt the formatting (by removing the BankStick or Power-Off), the firmware will try it again so long until it has been completed.Best Regards, Thorsten.
bosone Posted August 5, 2003 Author Report Posted August 5, 2003 AHHH!!!!!simpler than it seems!! thanks!BTW... was this written somewhere??
