Midibox FM - Frontpage inconsistent
Since there is no separate section for frontpage related messages and i am not sure who to bother with it through pm (wilba, thorsten, nils?)
I noticed the following. On the Frontpage is says:
2009-10-04 MIDIbox FM V1 V1.1e
then if you click on V1.1e you goto the Midibox FM changelog site which says:
MIDIbox FM Change Log
Last Release: V1.1c @ 2009-10-04
* V1.1d
o built for MIOS V1.9g (or higher) to support new encoder types.
Rotary encoders won't work with older MIOS versions!
o a new SysEx command allows to store the current patch into EEPROM/BankStick.
It can be used of no Control Surface is available - parameters can be changed via CC or SysEx
o volume parameters now updated immediately on CC #28..#31 changes
o reduced intensity of LFO/EG5 Pitch Depth parameter
If you load the actual firmware in you Midibox FM it says: V1.1d
So i think someone screwed up...just a little bit :rolleyes:
ucapps.de is my website, as you can see at the bottom of each page.
The .zip file got the wrong version number (v1.1d is the right one), I will change the filename, and also fix the documentation.
Posted (edited)
Ofcourse, don't know what i was thinking :whistle:
Anyway thanks for making those changes, less chance of possible confusion.
Edited by Shuriken
