Shuriken Posted December 23, 2009 Posted December 23, 2009 Since there is no separate section for frontpage related messages and i am not sure who to bother with it through pm (wilba, thorsten, nils?) I noticed the following. On the Frontpage is says: 2009-10-04 MIDIbox FM V1 V1.1e then if you click on V1.1e you goto the Midibox FM changelog site which says: MIDIbox FM Change Log Last Release: V1.1c @ 2009-10-04 * V1.1d o built for MIOS V1.9g (or higher) to support new encoder types. Rotary encoders won't work with older MIOS versions! o a new SysEx command allows to store the current patch into EEPROM/BankStick. It can be used of no Control Surface is available - parameters can be changed via CC or SysEx o volume parameters now updated immediately on CC #28..#31 changes o reduced intensity of LFO/EG5 Pitch Depth parameter If you load the actual firmware in you Midibox FM it says: V1.1d So i think someone screwed up...just a little bit :rolleyes:
TK. Posted December 23, 2009 Posted December 23, 2009 ucapps.de is my website, as you can see at the bottom of each page. The .zip file got the wrong version number (v1.1d is the right one), I will change the filename, and also fix the documentation. Best Regards, Thorsten.
Shuriken Posted December 25, 2009 Author Posted December 25, 2009 (edited) ucapps.de is my website, as you can see at the bottom of each page. The .zip file got the wrong version number (v1.1d is the right one), I will change the filename, and also fix the documentation. Best Regards, Thorsten. Ofcourse, don't know what i was thinking :whistle: Anyway thanks for making those changes, less chance of possible confusion. Edited December 25, 2009 by Shuriken
