[SOLVED] bankstick(s) not working
mescalinum
hi
I'm finishing a modular MBSID. actually I've done 1 CORE_V3, 1 SID_V2, 1 LCD 16x2 and works like a charm.
I wanted to add banksticks.
I made a little two-socket on veroboard (see attached image) (I used eagle cause it helped me to cross the less wires while working on a single layer)
anyway, the bankstick appears dead, I double-double-checked solderings, wiring, checked for shorts. I also checked that I have the two air-wires on the core (J4:SC->pin28 and J10:PWM->pin17).
the symptom is: when I send program change, it says <No Bankstick>.
I'm stuck, I don't know what to troubleshoot further
any help would be appreciated, thank you
EDIT: oops, it seems the attached image never got here.
here it is:
The schem is correct. A picture of the veroboard might help :) Some shots in the dark:
- R2/R12 on the core not mounted/wrong value
- Cable between core and bankstick is the wrong way around or broken
- You made a mistake in the eagle->veroboard process
thanks for your interest
sorry, I do not have a camera that can take decent photos, so I toke a couple, and added visual hints to one, in case you can't see every spot
(click to enlarge)
by the way, here are some test I made: (I'm repeating test now, just before hitting SEND)
with the bankstick circuit unplugged and ICs unmounted(looking at the schematic I made in eagle), using OHM-Meter:
- every IC pin that should be connected to GND, it is in connection with GND pin. every other: not.
- every IC pin that should be connected to +5V, it is in connection with +5V pin. every other: not.
- the 2 wire data bus does not touch +5V neither GND
- the 2 wire data bus is consistent (J4:2 touches only IC1:6 and IC2:6, J4:3 touches only IC1:5 and IC2:5)
with the bankstick attached to core, and core powered on, I can measure 5V between GND and 5v on every IC
that should exclude problems in the bankstick circuit itself
R2: ok (brown,black,red,gold = 10*100 = 1k)
R12: ok 1k too
as I said (text in the photo), I refer to red wire on ribbon cable as GND, and I measured +5V between GND and +5V on the bankstick circuit
given the tests I made above, it should be very unlikely.
unfortunately I don't have access to a logic probe or an oscilloscope... I don't know what to do then.
every other part is functional (sid functions, audio output, midi io, etc..)
I tried also 24LC256 ICs (always from Microchip) but same result <No BankStick>
this should exclude a fried IC.
the only thing I couldn't check now is the 2 wire IIC bus... later I'll dismount the core module again and do some more tests...
btw, I remember having tested with OHMmeter every single wire after etching CORE, prior to begin soldering
damn! :D
i got some time to unmount and check CORE module: air-wire from IIC pin to R12 was soldered to the wrong node
so I fixed it, and the midibox started to see external banks :)
sorry for the fuss
(I don't know how to put [sOLVED] in the subject so that this can be helpful to someone...)
cheers!
This looks great! What did you use to cut the case like that? That's a very precise, tight seam.
I first used a manual iron saw (30-40cm blade).
Then I smoothed the cut with a belt sander, and then used fine-grain sandpaper - sticked on a very straight plane - to refinish by hand.
If you do not have belt sander you can just do papersand by hand... it's just a bit more work.
Well, that sure beats the hell out of the dremel I've been using for my plastic cuts. A saw like that is a little out of my price range, but it's hard to argue with your results. Beautiful work!
