dear Midiboxer,
i finished my SEQ V4 and it 's a amazing sequencer but i have a little problem when i try to sequence my Boss DR660
it seem that when i trig two sound together for example two BD in 1,5,9,13 there is a little bit of gap
I believed that came of my dr660 but i tested with Nuendo and no gap
Then i tried to sequencer my MB6582 and some strange think happend
I build this somple sequence
C1-C2-C1-C2-C1-C2-C1-C2- and the second C2 note doesn't play correctly, just like i had a portamento
i think that the Midi out signal is too small and there is a bad intepretation about the both machine
I bought the Core32 on the SmashTV web'shop and there is only carbon resistor on the kit
Do you think if i change the both 220ohm resistor of the Midi out with 1% metal film resistor it will resolve this problem?
or any other idea to solve the problem will be fun
thank you for your help
this issue is very likely not related to the resistor (and especially not to the tolerance value).
To get a better understanding about the issue I need more input.
Are the two notes played from a single track, or from two different tracks?
Could you please post the track content? Just open MIOS Studio and type "track <track-number>" in the MIOS32 terminal.
E.g., to get the informations of the first track, type "track 1"
Are two notes played at the same time again like in the first example?
Are the notes sent over the same MIDI channel?
If not: check the step lengths (-> parameter layer C) - if the length value of C-1 is higher than 100% followed by C-2 on the next step, a slide will be triggered.
If this doesn't help, please post the track content for this example as well.
Posted (edited)
Yes the btoh sound are played from the same track
[1931.593] track 1
[1975.546] track 1
[1975.538] Track Parameters of G1T1
[1975.538] ========================
[1975.538] ParInstruments 16
[1975.538] ParLayers 1
[1975.538] ParSteps 64
[1975.538] TrgInstruments 16
[1975.538] TrgLayers 1
[1975.538] TrgSteps 64
[1975.538] EventMode 3 (Drum )
[1975.540] # | | | | | | | | | | | | | | | | |
[1975.540] Name ' BD SD CH PH OH MA CP CY LT MT HT RS CB Smp1 Smp2 Smp3 '
[1975.540] TrackMode 1 (Normal)
[1975.540] TrackModeFlags 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off)
[1975.540] MIDI_Port 0x00 (Def. )
[1975.540] MIDI_Channel 9 (#10)
[1975.540] DirectionMode 0 (Forward)
[1975.542] StepsForward 0 (1 Steps)
[1975.542] StepsJumpBack 0 (0 Steps)
[1975.542] StepsReplay 0
[1975.542] StepsRepeat 0 (0 times)
[1975.542] StepsSkip 0 (0 Steps)
[1975.542] StepsRepeatSkipInterval 3 (4 Steps)
[1975.542] Clockdivider 15 (16/384 ppqn)
[1975.542] Triplets 0 (no)
[1975.542] SynchToMeasure 0 (no)
[1975.542] Length 15 (16 Steps)
[1975.542] Loop 0 (Step 1)
[1975.543] TransposeSemitones 0 (+0)
[1975.543] TransposeOctaves 0 (+0)
[1975.543] MorphMode 0 (off)
[1975.543] MorphDestinationRange 0 (1..16)
[1975.545] HumanizeMode 0 (Note: off, Velocity: off, Length: off)
[1975.545] HumanizeIntensity 0
[1975.545] GrooveStyle 0
[1975.545] GrooveIntensity 0
[1975.545] TriggerAsngGate 1 (A)
[1975.545] TriggerAsngAccent 0 (-)
[1975.545] TriggerAsngRoll 0 (-)
[1975.545] TriggerAsngGlide 0 (-)
[1975.545] TriggerAsgnSkip 0 (-)
[1975.545] TriggerAsgnRandomGate 0 (-)
[1975.545] TriggerAsgnRandomValue 0 (-)
[1975.547] TriggerAsgnNoFx 0 (-)
[1975.547] DrumParAsgnA 3 (Vel. )
[1975.547] DrumParAsgnB 0 (None )
[1975.547] EchoRepeats 0
[1975.547] EchoDelay 7 ( 8 )
[1975.547] EchoVelocity 15
[1975.547] EchoFeedbackVelocity 15 (75
[1975.547] EchoFeedbackNote 24 (+0)
[1975.547] EchoFeedbackGatelength 20 (100
[1975.547] EchoFeedbackTicks 20 (100
[1975.547] LFO_Waveform 0 ( off )
[1975.547] LFO_Amplitude 192 (64)
[1975.549] LFO_Phase 0 (0
[1975.549] LFO_Interval 15 (16 Steps)
[1975.549] LFO_Reset_Interval 15 (16 Steps)
[1975.549] LFO_Flags 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off)
[1975.549] LFO_ExtraCC 0
[1975.549] LFO_ExtraCC_Offset 64
[1975.549] LFO_ExtraCC_PPQN 6 (96 ppqn)
[1975.549] NoteLimitLower 0
[1975.549] NoteLimitUpper 0
[1975.552] # MIDI Notes for Drum Instruments:
[1975.552] ConstArrayA 0x24 0x26 0x2a 0x2c 0x2e 0x46 0x27 0x37 0x29 0x2b 0x2f 0x4b 0x38 0x2c 0x3c 0x3d
[1975.552] # MIDI Velocity:
[1975.553] ConstArrayB 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.553] # MIDI Accent Velocity:
[1975.553] ConstArrayC 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f
[1975.553] # Parameter Layers:
[1975.555] Par 0x000 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.555] Par 0x010 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.557] Par 0x020 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.559] Par 0x030 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.559] Par 0x040 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.559] Par 0x050 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.560] Par 0x060 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.560] Par 0x070 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.562] Par 0x080 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.562] Par 0x090 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.564] Par 0x0a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.564] Par 0x0b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.566] Par 0x0c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.566] Par 0x0d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.568] Par 0x0e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.568] Par 0x0f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.570] Par 0x100 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.570] Par 0x110 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.572] Par 0x120 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.572] Par 0x130 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.573] Par 0x140 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.573] Par 0x150 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.575] Par 0x160 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.575] Par 0x170 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.577] Par 0x180 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.577] Par 0x190 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.579] Par 0x1a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.579] Par 0x1b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.581] Par 0x1c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.581] Par 0x1d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.583] Par 0x1e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.583] Par 0x1f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.585] Par 0x200 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.585] Par 0x210 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.586] Par 0x220 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.586] Par 0x230 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.588] Par 0x240 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.588] Par 0x250 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.590] Par 0x260 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.590] Par 0x270 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.592] Par 0x280 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.592] Par 0x290 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.594] Par 0x2a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.595] Par 0x2b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.596] Par 0x2c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.596] Par 0x2d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.597] Par 0x2e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.597] Par 0x2f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.599] Par 0x300 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.599] Par 0x310 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.601] Par 0x320 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.601] Par 0x330 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.603] Par 0x340 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.603] Par 0x350 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.605] Par 0x360 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.605] Par 0x370 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.607] Par 0x380 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.607] Par 0x390 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.609] Par 0x3a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.609] Par 0x3b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.610] Par 0x3c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.611] Par 0x3d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.612] Par 0x3e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.612] Par 0x3f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[1975.612] # Trigger Layers:
[1975.614] Trg 0x000 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x00 0x00 0x00 0x00 0x00 0x00
[1975.614] Trg 0x010 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.616] Trg 0x020 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.616] Trg 0x030 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.618] Trg 0x040 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.618] Trg 0x050 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.620] Trg 0x060 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.620] Trg 0x070 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.621] Trg 0x080 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.621] Trg 0x090 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.623] Trg 0x0a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.623] Trg 0x0b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.625] Trg 0x0c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.625] Trg 0x0d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.627] Trg 0x0e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.627] Trg 0x0f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[1975.627] done.
the notes are send over the same midi channel
here is the content of this track
[[2427.031] track 9
[2427.013] Track Parameters of G3T1
[2427.013] ========================
[2427.013] ParInstruments 1
[2427.013] ParLayers 4
[2427.013] ParSteps 256
[2427.013] TrgInstruments 1
[2427.013] TrgLayers 8
[2427.013] TrgSteps 256
[2427.013] EventMode 0 (Note )
[2427.013] # | | | | | | | | | | | | | | | | |
[2427.013] Name ' '
[2427.013] TrackMode 1 (Normal)
[2427.015] TrackModeFlags 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off)
[2427.015] MIDI_Port 0x00 (Def. )
[2427.015] MIDI_Channel 0 (#1)
[2427.015] DirectionMode 0 (Forward)
[2427.015] StepsForward 0 (1 Steps)
[2427.015] StepsJumpBack 0 (0 Steps)
[2427.015] StepsReplay 0
[2427.015] StepsRepeat 0 (0 times)
[2427.015] StepsSkip 0 (0 Steps)
[2427.016] StepsRepeatSkipInterval 3 (4 Steps)
[2427.016] Clockdivider 15 (16/384 ppqn)
[2427.016] Triplets 0 (no)
[2427.016] SynchToMeasure 0 (no)
[2427.016] Length 15 (16 Steps)
[2427.016] Loop 0 (Step 1)
[2427.017] TransposeSemitones 0 (+0)
[2427.017] TransposeOctaves 0 (+0)
[2427.017] MorphMode 0 (off)
[2427.017] MorphDestinationRange 0 (1..16)
[2427.019] HumanizeMode 0 (Note: off, Velocity: off, Length: off)
[2427.019] HumanizeIntensity 0
[2427.019] GrooveStyle 0
[2427.019] GrooveIntensity 0
[2427.019] TriggerAsngGate 1 (A)
[2427.019] TriggerAsngAccent 2 (B)
[2427.020] TriggerAsngRoll 3 ©
[2427.020] TriggerAsngGlide 4 (D)
[2427.020] TriggerAsgnSkip 5 (E)
[2427.020] TriggerAsgnRandomGate 6 (F)
[2427.020] TriggerAsgnRandomValue 7 (G)
[2427.020] TriggerAsgnNoFx 8 (H)
[2427.020] DrumParAsgnA 0 (None )
[2427.020] DrumParAsgnB 0 (None )
[2427.020] EchoRepeats 0
[2427.020] EchoDelay 7 ( 8 )
[2427.021] EchoVelocity 15
[2427.021] EchoFeedbackVelocity 15 (75
[2427.021] EchoFeedbackNote 24 (+0)
[2427.021] EchoFeedbackGatelength 20 (100
[2427.021] EchoFeedbackTicks 20 (100
[2427.021] LFO_Waveform 0 ( off )
[2427.022] LFO_Amplitude 192 (64)
[2427.022] LFO_Phase 0 (0
[2427.022] LFO_Interval 15 (16 Steps)
[2427.022] LFO_Reset_Interval 15 (16 Steps)
[2427.023] LFO_Flags 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off)
[2427.023] LFO_ExtraCC 0
[2427.023] LFO_ExtraCC_Offset 64
[2427.023] LFO_ExtraCC_PPQN 6 (96 ppqn)
[2427.023] NoteLimitLower 0
[2427.025] NoteLimitUpper 0
[2427.026] # Parameter Layer Assignments:
[2427.026] ConstArrayA 0x01 0x03 0x04 0x09 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01 0x01
[2427.026] # CC Assignments:
[2427.027] ConstArrayB 0x01 0x10 0x11 0x12 0x13 0x14 0x15 0x16 0x17 0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x1e
[2427.027] # Constant Array C:
[2427.027] ConstArrayC 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.027] # Parameter Layers:
[2427.028] Par 0x000 0x24 0x24 0x30 0x24 0x24 0x24 0x30 0x24 0x24 0x24 0x30 0x24 0x24 0x24 0x30 0x24
[2427.029] Par 0x010 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.030] Par 0x020 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.033] Par 0x030 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.033] Par 0x040 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.033] Par 0x050 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.034] Par 0x060 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.034] Par 0x070 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.036] Par 0x080 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.036] Par 0x090 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.038] Par 0x0a0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.038] Par 0x0b0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.039] Par 0x0c0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.040] Par 0x0d0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.041] Par 0x0e0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.042] Par 0x0f0 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24 0x24
[2427.043] Par 0x100 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.044] Par 0x110 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.045] Par 0x120 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.045] Par 0x130 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.047] Par 0x140 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.047] Par 0x150 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.050] Par 0x160 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.050] Par 0x170 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.052] Par 0x180 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.052] Par 0x190 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.052] Par 0x1a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.053] Par 0x1b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.054] Par 0x1c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.055] Par 0x1d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.057] Par 0x1e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.057] Par 0x1f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2427.059] Par 0x200 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.059] Par 0x210 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.061] Par 0x220 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.061] Par 0x230 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.062] Par 0x240 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.062] Par 0x250 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.064] Par 0x260 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.064] Par 0x270 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.065] Par 0x280 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.066] Par 0x290 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.067] Par 0x2a0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.068] Par 0x2b0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.070] Par 0x2c0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.070] Par 0x2d0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.072] Par 0x2e0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.072] Par 0x2f0 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47 0x47
[2427.074] Par 0x300 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.074] Par 0x310 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.075] Par 0x320 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.075] Par 0x330 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.076] Par 0x340 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.077] Par 0x350 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.079] Par 0x360 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.079] Par 0x370 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.081] Par 0x380 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.081] Par 0x390 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.083] Par 0x3a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.083] Par 0x3b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.084] Par 0x3c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.085] Par 0x3d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.085] Par 0x3e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.086] Par 0x3f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.086] # Trigger Layers:
[2427.087] Trg 0x000 0x55 0x55 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11
[2427.088] Trg 0x010 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11
[2427.089] Trg 0x020 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.089] Trg 0x030 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.092] Trg 0x040 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.092] Trg 0x050 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.093] Trg 0x060 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.093] Trg 0x070 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.096] Trg 0x080 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.096] Trg 0x090 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.096] Trg 0x0a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.097] Trg 0x0b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.099] Trg 0x0c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.099] Trg 0x0d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.101] Trg 0x0e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.101] Trg 0x0f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2427.101] done.
i hope it does meen something for you
Edited by xarolium
Posted (edited)
I made a new pattern with only the both sound on the track 1
Firdt BD in C1 and the second in F#2
I didn't change the name of the second BD and it was play on the SD layer
here is the content of the track 1
[2914.359] track 1
[2914.313] Track Parameters of G1T1
[2914.313] ========================
[2914.313] ParInstruments 16
[2914.313] ParLayers 1
[2914.313] ParSteps 64
[2914.313] TrgInstruments 16
[2914.313] TrgLayers 1
[2914.313] TrgSteps 64
[2914.313] EventMode 3 (Drum )
[2914.313] # | | | | | | | | | | | | | | | | |
[2914.315] Name ' BD SD CH PH OH MA CP CY LT MT HT RS CB Smp1 Smp2 Smp3 '
[2914.315] TrackMode 1 (Normal)
[2914.315] TrackModeFlags 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off)
[2914.315] MIDI_Port 0x00 (Def. )
[2914.315] MIDI_Channel 9 (#10)
[2914.315] DirectionMode 0 (Forward)
[2914.317] StepsForward 0 (1 Steps)
[2914.317] StepsJumpBack 0 (0 Steps)
[2914.317] StepsReplay 0
[2914.317] StepsRepeat 0 (0 times)
[2914.317] StepsSkip 0 (0 Steps)
[2914.317] StepsRepeatSkipInterval 3 (4 Steps)
[2914.317] Clockdivider 15 (16/384 ppqn)
[2914.317] Triplets 0 (no)
[2914.318] SynchToMeasure 0 (no)
[2914.318] Length 15 (16 Steps)
[2914.318] Loop 0 (Step 1)
[2914.318] TransposeSemitones 0 (+0)
[2914.318] TransposeOctaves 0 (+0)
[2914.318] MorphMode 0 (off)
[2914.318] MorphDestinationRange 0 (1..16)
[2914.320] HumanizeMode 0 (Note: off, Velocity: off, Length: off)
[2914.320] HumanizeIntensity 0
[2914.320] GrooveStyle 0
[2914.320] GrooveIntensity 0
[2914.320] TriggerAsngGate 1 (A)
[2914.320] TriggerAsngAccent 0 (-)
[2914.320] TriggerAsngRoll 0 (-)
[2914.320] TriggerAsngGlide 0 (-)
[2914.320] TriggerAsgnSkip 0 (-)
[2914.320] TriggerAsgnRandomGate 0 (-)
[2914.320] TriggerAsgnRandomValue 0 (-)
[2914.320] TriggerAsgnNoFx 0 (-)
[2914.322] DrumParAsgnA 3 (Vel. )
[2914.322] DrumParAsgnB 0 (None )
[2914.322] EchoRepeats 0
[2914.322] EchoDelay 7 ( 8 )
[2914.322] EchoVelocity 15
[2914.322] EchoFeedbackVelocity 15 (75
[2914.322] EchoFeedbackNote 24 (+0)
[2914.322] EchoFeedbackGatelength 20 (100
[2914.322] EchoFeedbackTicks 20 (100
[2914.324] LFO_Waveform 0 ( off )
[2914.324] LFO_Amplitude 192 (64)
[2914.324] LFO_Phase 0 (0
[2914.324] LFO_Interval 15 (16 Steps)
[2914.324] LFO_Reset_Interval 15 (16 Steps)
[2914.324] LFO_Flags 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off)
[2914.324] LFO_ExtraCC 0
[2914.324] LFO_ExtraCC_Offset 64
[2914.326] LFO_ExtraCC_PPQN 6 (96 ppqn)
[2914.326] NoteLimitLower 0
[2914.326] NoteLimitUpper 0
[2914.326] # MIDI Notes for Drum Instruments:
[2914.326] ConstArrayA 0x24 0x36 0x2a 0x2c 0x2e 0x46 0x27 0x37 0x29 0x2b 0x2f 0x4b 0x38 0x2c 0x3c 0x3d
[2914.326] # MIDI Velocity:
[2914.328] ConstArrayB 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.328] # MIDI Accent Velocity:
[2914.328] ConstArrayC 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f 0x7f
[2914.328] # Parameter Layers:
[2914.330] Par 0x000 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.330] Par 0x010 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.332] Par 0x020 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.332] Par 0x030 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.334] Par 0x040 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.334] Par 0x050 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.336] Par 0x060 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.336] Par 0x070 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.338] Par 0x080 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.338] Par 0x090 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.339] Par 0x0a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.339] Par 0x0b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.341] Par 0x0c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.341] Par 0x0d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.343] Par 0x0e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.343] Par 0x0f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.345] Par 0x100 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.345] Par 0x110 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.347] Par 0x120 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.347] Par 0x130 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.349] Par 0x140 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.349] Par 0x150 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.351] Par 0x160 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.351] Par 0x170 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.352] Par 0x180 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.352] Par 0x190 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.354] Par 0x1a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.354] Par 0x1b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.356] Par 0x1c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.356] Par 0x1d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.358] Par 0x1e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.358] Par 0x1f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.360] Par 0x200 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.360] Par 0x210 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.362] Par 0x220 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.362] Par 0x230 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.364] Par 0x240 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.364] Par 0x250 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.365] Par 0x260 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.365] Par 0x270 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.367] Par 0x280 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.367] Par 0x290 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.369] Par 0x2a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.369] Par 0x2b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.371] Par 0x2c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.371] Par 0x2d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.372] Par 0x2e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.372] Par 0x2f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.375] Par 0x300 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.375] Par 0x310 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.377] Par 0x320 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.377] Par 0x330 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.378] Par 0x340 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.378] Par 0x350 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.380] Par 0x360 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.380] Par 0x370 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.382] Par 0x380 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.382] Par 0x390 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.384] Par 0x3a0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.384] Par 0x3b0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.386] Par 0x3c0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.386] Par 0x3d0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.388] Par 0x3e0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.388] Par 0x3f0 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[2914.388] # Trigger Layers:
[2914.390] Trg 0x000 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x11 0x00 0x00 0x00 0x00 0x00 0x00
[2914.390] Trg 0x010 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.391] Trg 0x020 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.391] Trg 0x030 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.393] Trg 0x040 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.393] Trg 0x050 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.395] Trg 0x060 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.395] Trg 0x070 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.397] Trg 0x080 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.397] Trg 0x090 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.399] Trg 0x0a0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.399] Trg 0x0b0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.400] Trg 0x0c0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.400] Trg 0x0d0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.402] Trg 0x0e0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.402] Trg 0x0f0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
[2914.402] done.
here is the gap i recorded with Nuendo
Edited by xarolium
Alright!
This delay (the gap) is caused by the common MIDI baudrate - there is no way to prevent this, musicians are living with this effect since almost 30 years now ;)
I guess that it is around 650 uS - can you confirm this by measuring this time with your waveform editor?
Here a comparison which demonstrates the delay between USB MIDI (MBSEQ sends over USB1), running status optimized MIDI (MBSEQ sends over OUT1), and non-optimized MIDI output (not used by MBSEQ)
The full article can be found here:
MBSID issue: the track is clean (I'm able to load this pattern into my own MBSEQ)
Therefore I've only two explanations for this effect: either a second track plays C-1 over the same MIDI channel, so that glide is triggered, or your MBSID patch has portamento permanently enabled.
1st assumption can be checked by playing G3T1 in solo mode
2nd assumption can be checked by playing the default patch of MBSID (located at A001 if you haven't overwritten it yet)
ok i know that there is a little gap with MIDI control but here the gap is more than 650us
i can hear the gap between the both BD
and i check my MBSID sound and it did the same thing with the A001 sound
Is it possible that the problem come from the SD card
because when i put it on 5v the card became very hot and didn't work correctly anymore
i checked it and my MicroSD adaptator "burned" ( only the cover)
After that i put it on 3,3V and it work correctly but maybe my MicroSD was damage
I'll try with an other
I hope it will solve my problem because i couldn't use the sequencer like it
I don't see a relation between the SD Card and delays on MIDI Out.
Are you able to record the MIDI Output into Nuendo with a MIDI interface connected to your PC?
This would be a nice debugging help.
Another interesting experiment: open MIOS Studio, select your MIDI interface as MIDI Input and play the notes.
The timestamps in MIDI IN monitor will show you the delays very accurately in mS resolution. What delays do you see there (please post the log)
Thank you TK for your interest of my problem
I record the MIDI out of the SEQV4 and it give me that
When i delete the parameter CC32 all it's ok, the problem disapear
I would like to know how it's possible to not send other parameter than note and velocity on the SEQV4
I create a new track with the same note and i record the MIDI out in Nuendo and i found that there is Note + Velocity + CC32 + CC33 + CC34 and CC35 who was recording
How can i solve this problem ?
It looks like you've assigned the BLM_SCALAR output port to IN1, can you confirm this?
Go into the MIDI menu, select the Misc page, and check the port to which BLM_SCALAR has been assigned. Select "off" to disable it.
Yes i confirm that the BLM_scalar was in IN1
i select OFF to disable it and it was ok now
What is this fonction ?
Alright - this explains all your delay/latency issues.
A MIDI port assigned to BLM_SCALAR shouldn't be used for normal MIDI output.
The function is secret ;)
