ultra Posted May 8, 2010 Posted May 8, 2010 i know this is simple stuff, but for some reason i can't get it. i have an integer that i want to turn into a float. int intValue2 = MBLIVE_TranslateFrom21Bit(&val2); float decValue = intValue2; DEBUG_MSG("%d", intValue2); DEBUG_MSG("%f", decValue); for sure intValue2 gives me the number i want. i read online that i can simply assign an int to a float and it'll become a float, but my second DEBUG_MSG just outputs a blank line. i also tried using (float) before the int and that didn't work either. any ideas? thanks, ultra
TK. Posted May 8, 2010 Posted May 8, 2010 There is a simple answer: the simplified (s)printf function of MIOS32 doesn't support %f See also http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F003_debug_messages%2FREADME.txt Workaround: write DEBUG_MSG("%d.%03d", (int)floatValue, (int)(floatValue*1000) % 1000); Best Regards, Thorsten.
ultra Posted May 8, 2010 Author Posted May 8, 2010 thanks a lot tk, that works quite well. i'm also struggling to understand this: my float is always a positive int (i guess that's obvious since i was creating it using an int). for the correct value, the decimal should be shifted 3 places left. i multiply by .001, but i end up with .000, at least using what you gave me to output to mios terminal. is there something else i must do? i would think this would work in most cases, but is there something specific to the compiler regarding floats? too much OOP has spoiled me. i have to work with ints in the first place and convert them back to .001 of the value because i'm bit shifting some values to 7 bits, sending over midi from ableton live, and reassembling them on the other side. i didn't see a good way to just send a floating point value (doubt there is one) so i break up the values before and after the decimal and send them separately. so this is the part where i try to reassemble it on the other side. ultra
TK. Posted May 8, 2010 Posted May 8, 2010 It could be important to cast a value to the correct type before doing such operations. A code snippet would help to understand what is going wrong. On the other hand: If your value is an Int anyhow, and you only want to reduce the resolution to get a 7bit value, why not using "intValue / 1000"? Float operations are expensive (performance wise), but fixed point divisions (and multiplications) of integer values are fast since they are supported by the hardware. Best Regards, Thorsten.
ultra Posted May 8, 2010 Author Posted May 8, 2010 ok here's a code snippet. i changed it to /1000 and directly set the first values, even though i'm getting them in a different way. i have this: int intValue1 = 1267; int intValue2 = 474; float decValue = intValue2; float totalValue = (decValue / 1000); DEBUG_MSG("%d", intValue1); DEBUG_MSG("%d", intValue2); DEBUG_MSG("%d.%03d", (int)totalValue, ((int)totalValue*1000) % 1000); and end up with this: 00000021173501 ms | 1267 00000021173501 ms | 474 00000021173501 ms | 0.000 1267 and 474 are values i received from live, which started as 1267.474. in the end, i want my 474 to return to .474 so i can add the 1267 to it and get my original value back. i haven't done the final adding operation yet because i want to get the .474 working first. thanks, ultra
ultra Posted May 8, 2010 Author Posted May 8, 2010 also, to be more complete with information, not using / 1000 gives me this: 00000021437039 ms | 1267 00000021437039 ms | 474 00000021437039 ms | 474.000 so it's sorta working!
philetaylor Posted May 8, 2010 Posted May 8, 2010 I think you have to 'cast' the result of the calculation as otherwise the result will be considered int: float totalValue = (float)(decValue / 1000); Cheers Phil
TK. Posted May 8, 2010 Posted May 8, 2010 Yes! But to keep the float resolution, you should write: float totalValue = (float)decValue / 1000; [/code] or better (I don't know if this really makes a difference, but I always add .0 to float constants to force the correct type): [code] float totalValue = (float)decValue / 1000.0; Best Regards, Thorsten.
philetaylor Posted May 8, 2010 Posted May 8, 2010 (edited) Actually thinking about it, you should cast decValue to float 'first'. This ensures that the whole calculation uses floating point arithmetic and not integer. float totalValue = (float)decValue / 1000; Cheers Phil EDIT: TK beat me to it (again!) Edited May 8, 2010 by philetaylor
ultra Posted May 9, 2010 Author Posted May 9, 2010 yeah i don't really get it. i tried: (float)decValue / 1000 (float)decValue / 1000.0 (float)(decValue / 1000) it all gives me .000
ultra Posted May 9, 2010 Author Posted May 9, 2010 the number i'm working with right now is 84. i tried dividing by 10 to see what happens, and i get 8.0. so for some reason it's rounding off or just removing the decimal.
TK. Posted May 9, 2010 Posted May 9, 2010 The conversion in DEBUG_MSG is wrong. Instead of: DEBUG_MSG("%d.%03d", (int)totalValue, ((int)totalValue*1000) % 1000); [/code] write: [code] DEBUG_MSG("%d.%03d", (int)totalValue, (int)(totalValue*1000.0) % 1000); Best Regards, Thorsten.
