Hi ,
After years of sleep I powered on my Roland D50 .
It works fine...very fine but aftertouch ( from its keyboard ) do not responds. :no:
From MIDI aftertouch works normally so it is a keyboard sensors problem.
In the net i read that it is a common problem on some Roland products ( JD800,D50 )
and it is caused from resistor in the pressure sensor amplifier that change its value
in the years.
Is anybody experienced of this or knows a link useful for solving this problem? :console:
Best Regards
Antix
Hi ,
in the years.
Best Regards
Antix
This maybe? http://www.bustedgear.com/repair_Roland_d50_key_contacts_2.html
Hi Shuriken,
Thank You for the answer but unfortunately I have not a contact problem.
Key Contact and dynamic works fine .
The problem is the aftertouch.
I am start to thinking that maibe useful a D50 schematic to see the zone of
aftertouch and make some measures.
Effectively if I push very hard on keys a very minimal sound variation exist.
At the end in my town is there a Roland service center but I'm sure they will
ask me a lot of money....so first I wont to try myself.
Regards
Antix
P.S. the site You indicate is fine
Yes, I will ask.
It seems that a lot of aftertouch sensors going to oxidize then a
good cleaning may solve the problem.
Thank for the link for the manual.
Regards
Antix
  • 4 weeks later...
Sorry for delay.
On the bender board I have resoldered cursors ( pot ) and other SMD and PTH.
The whole cause of malfunction was ( like old philips television ) a degradation of the PTH solderings.
You can see , with magnifyng lens , like a little darker circle in the soldering around the pin.
After resoldering pins of the cursors aftertouch starts ( restarts ) to work but I gave a little shot to all the soldering on this board.
Regards
Antix
