Simple question here. I want to be able to hold one note down and tap a couple other notes while the first note is still being held. How would I program this into the seqv4? Do I assign (in the event page) different layers to control notes as well or lenghts as well. I basically want one notes lenght to span the track and the other notes to be shorter without the first note fading out because the length layer is shorter to make the quick notes fade out fast. Am I making sense here? Or do I use a initialize the track for chord style?
Regards,
echo
Since each track only supports a single length layer, you have to realize this on a different way:
use one track for the stretched or (better) sustained note
use another track for the short notes.
Assign both tracks to the same MIDI port and channel.
