hi folks,
I'm about to build a bigger VU-meter using the LM3915.
The IC has open collector outputs which can sink 30 mA max. I need 120mA per output.
first Idea: 4009 inverting buffers (with pullup reistors) and some ULN2803 (or 2804) driver ICs. But I guess, that's pretty hardcore.
second Idea: would a simple PNP-transistor per output work? Any Idea, which type would be suitable for 120mA@5V ?
thanks in advance.
  • 4 weeks later...
hi folks,
thanks in advance.
I prefer a PNP-transistor type BD136 or similar
Regards,
Janis
BD136.pdf
Edited by Janis1279
  • 3 weeks later...
The LM 3915 outputs will drive solid state relays. We once built some 3 metre tall VU meters for a night club, using mains bulbs. Later version added lamp pre-heat, (basically a small dimmer feeding a little current into each lamp to warm the filaments, and reduce fatigue failure).
On the same tack, using filament heating transformers, you can build 7 segment displays from fluorescent tubes. 4 metre high digital clock, anyone?
