GM5 powering core, din, dout and 64 leds
widdly
Short answer: No.
Long answer: No. USB ports can only supply a very small amount of current. If you overdo it you'll probably kill your motherboard. Guesstimating 50mA for the core, 20mA per DIN/DOUT and 10mA per LED you're looking at ~800mA, which is way over usb spec.
Thanks for the reply.
I thought the LED's would draw less current since they are wired in a matrix with the shift registers so they are not actually all turned on at the same time. When it's running I figure only 8 LED's will be turned on at any moment. I suppose the situation will be different at power up before the shift registers are set up by the PIC.
