mastomo Posted June 12, 2010 Posted June 12, 2010 Hi everyone, i am building a MIDIbox SEQ V4 everything is solder, today was suppose to be the big day ... but not, when i powered on, nothing happen. indeed, The IC6 regulator 7805 get really hot and deliver only 1.5V i got 2 questions: - my regulator is working, i have test it, so what is the matter ? - about J2 jumper, how is it possible that a jumper is for connecting 0V with +5V ? one more thing, i am sure there is not short-circuit between pin 2 and pin 3 from IC6 thank you verymuch for your help, 'cause i need it :-) have a good day Thomas (from Paris)
strophlex Posted June 13, 2010 Posted June 13, 2010 Hi everyone, i am building a MIDIbox SEQ V4 everything is solder, today was suppose to be the big day ... but not, when i powered on, nothing happen. indeed, The IC6 regulator 7805 get really hot and deliver only 1.5V i got 2 questions: - my regulator is working, i have test it, so what is the matter ? - about J2 jumper, how is it possible that a jumper is for connecting 0V with +5V ? one more thing, i am sure there is not short-circuit between pin 2 and pin 3 from IC6 thank you verymuch for your help, 'cause i need it :-) have a good day Thomas (from Paris) Hi! J2 is not a jumper. It is a connector for a) suppling other devices with 5V dc or b) supplying the core module with 5V dc from another source when the PSU part of the module is not used. When you put jumper there you make a short cirquet and that's why your regulator gets hot. Remove the jumper and let's hope your regulator is OK. I did somthing similar once and it didn't brake the regulator. Good luck!
mastomo Posted June 13, 2010 Author Posted June 13, 2010 Hi Strophlex, many thankx for your message. well, i never put a jumper on J2 because it seems weird to me :-) but now, with your help, the function of J2 is understood. i've unplugged everything : J15a - J15b (LCD), J8 - J9 (DIN and DOUT) then the regulator is Working OK and delivered 5v as it should. But now, when i plugged my mbhp Core stm32 with Mios studio i got this message "no response from the core" as you can see, i need to work again and check everything because i got troubles coming from everywhere ... But i wont give up :-) have a good day
mastomo Posted August 9, 2010 Author Posted August 9, 2010 Hi there, a short message because my sequenceur is done ! I'm really happy of course :-) the trouble I got from my last post there was because of some wrong soldering ..... a silly mistake ..... Wish you a really nice summer !
