I didn't like any of the bezels and LED holders available at the time of designing the back panel, and I wanted the LED to look the same as the LEDs on the top panel, i.e. just poking through a hole in the panel. So I just made the hole 3mm diameter and glued the LED from the back using superglue. In case it's not obvious, header J2 (next to power switch) is where you connect the LED directly, resistor R81 does the current limiting.
Posted (edited)
Did you use some sort of black LED holder thingy Wilba for mkI and mkII?
Edited by Smithy
No, are you referring to the audio socket above the LED?
LOL! Yes.
I had completely forgotten the audio socket was directly above it.
