Aliã Bianco Posted September 11, 2010 Posted September 11, 2010 (edited) Hey guys, my core stop working... First question. without Optocoupler, led (TEST IN3) still lit is normal??? thanks! Edit: I put a led direct into J13 whit anode in +, and catode in -. ok. led flicks whith midi in. but if i put it in pin 2 and 3 of optocoupler (anode in 2, cathode in 3). led dont flicks. Is Normal? its my second optocoupler i'm very confused... :logik: ... Edited September 11, 2010 by Aliã Bianco
TK. Posted September 11, 2010 Posted September 11, 2010 Hi, without Optocoupler, led (TEST IN3) still lit is normal??? yes, because the LED will be supplied through the pull-up resistor R6 I put a led direct into J13 whit anode in +, and catode in -. ok. led flicks whith midi in. but if i put it in pin 2 and 3 of optocoupler (anode in 2, cathode in 3). led dont flicks. Is Normal? yes, because the optocoupler consumes power. Best Regards, Thorsten.
