Calphool Posted September 17, 2010 Posted September 17, 2010 Hello, I built an AOUT LC (used resistor networks for the 10k resistors rather than a bunch of discretes). I'm really confused on what happens when I use the function AOUT_Pin16bitSet(). For example, my expectation is that if I call AOUT_Pin16bitSet(0,32767), I'd see +5v on all the data output pins of the two 74hc595 chips, but instead the lower 3 of the second chip are zero, and the 7th pin of the first chip is 0. That seems like some kind of bit shift / carry problem, but I don't quite understand how that AOUT_Pin16bitSet() function works. I was using AOUT_Pin7bitSet successfully, but since that's only 7 bits, I think I'm losing one pin on each 74hc595, and I'd like to get the full 8 bits of output. What I need is the ability to correct my pitch levels in software since the hardware I'm interfacing my AOUT LC to isn't perfectly linear in its response, but 7 bits is too coarse. Any help someone could provide would be greatly appreciated. --Joe R.
nILS Posted September 17, 2010 Posted September 17, 2010 a) First of all: 32767 == 0x7FFF == 0111 1111 1111 1111b That's 15 bits not 16. Try 65535 == 0xFFFF Make sure the variable you use is unsigned 16bits. b) Show some source :) c) Can you confirm all of the outputs work properly using different set functions?
